16.5 inch wheels
Old May 30, 2015 | 04:33 PM
Rvaughn83's Avatar
Rvaughn83
16.5 inch wheels
I am looking for some input or suggestions on an alternative. I have an 82 f250 that I recently purchased. It has a couple inches of lift and noticed I needed a spare tire... So I google the tire size: 33x12.50R16.5 and nothing! I find a lot of stuff about the 16.5 inch wheels being not safe and all that. The tires are great but I do need a spare and a plan b for when I do need tires. I want to keep the same look of the truck. Thanks!
Old May 30, 2015 | 05:01 PM
Nothing Special's Avatar
Nothing Special
You could switch to 16" or 17" rims. Personally I like 16", but I hear it's getting easier to find sizes in 17".
An exact match for 33x12.50-16.5 in a 16" would be 317/68-16. In a 17" it would be 317/64-17. Neither of those is a real size, but if you look on a tire chart you ought to be able to find something close.
Old May 30, 2015 | 05:12 PM
maytag906's Avatar
maytag906
Those are probably old tires. You might have to buy a set of 5 if you want matching.
Old May 30, 2015 | 09:18 PM
Franklin2's Avatar
Franklin2
You can still buy 16.5 inch tires. There is not much selection, but mine has BF Goodrich 35-12.5-16.5 and I think you can still buy them.
For a spare, just get a plain ugly steel wheel and find a decent used 16 inch tire to put on it.
Only the 16.5 split rims are dangerous, and only dangerous to the person mounting the tire. You probably have aftermarket rims like I do, and they are not split rims and are not dangerous.
Here's a link to the ones I have. They are good tires. But I see they only make my size in 16.5 inch size anymore. I have a 4 inch lift for mine to fit.
All-Terrain T/A KO | BFGoodrich Tires
Old May 30, 2015 | 10:28 PM
Nothing Special
...Only the 16.5 split rims are dangerous, and only dangerous to the person mounting the tire. You probably have aftermarket rims like I do, and they are not split rims and are not dangerous...
I've also heard that 16.5" rims don't have a safety bead to help retain the tire bead. I'm not sure if that's true of all 16.5" rims. And I'm not sure how big of a safety issue it is either. But that's the main issue I've heard about 16.5" rims not being as safe as others (although yes, split rims would introduce another potential safety issue).
Old May 31, 2015 | 07:40 AM
Franklin2's Avatar
Franklin2
You only run into problems with the lack of a safety bead if you run very low tire pressure, for instance running in the sand on the beach. The rims I am running are aftermarket aluminum rims, so I would assume they have the safety bead feature, though I have never looked at them to see.
The "safety bead" feature is the grooves on each side of the wheel where the bead sits.
Old May 31, 2015 | 07:58 AM
InfantryCPT's Avatar
InfantryCPT
I ran into this (selection of rims and tires with my daughters truck) she has 16" on it now only because I found some (tires/rims) for a song (cheap), however trying to find replacement tires are difficult. 17" tires are all over craigslist, this will be the next set. The 16.5s dont exist down here unless you want military grade Hummer tires (37s)
Old Jun 1, 2015 | 02:15 PM
bert cook's Avatar
bert cook
i asked les swab about this a year ago and they said the cross over for the 9.50/16.5 was 265/75/r16
Old Jun 1, 2015 | 03:41 PM
Rvaughn83's Avatar
Rvaughn83
Thanks everyone for your hep, it's very much appreciated here is a pic
Here is a pic of the wheels. Whatever I get I want to keep the same height/look. Thank you everyone for your help!
Old Jun 1, 2015 | 08:34 PM
Franklin2's Avatar
Franklin2
Does this look like plan b in this link? Convert to 16 inch.
http://www.summitracing.com/parts/crr-3157880/overview/
Old Jun 1, 2015 | 08:50 PM
Rvaughn83's Avatar
Rvaughn83
YES!! Thanks so much for the link, helps tremendously.
Old Jun 7, 2015 | 10:31 AM
Nothing Special
Here's a quote from page 34 of the June issue of Jp magazine:
With the exception of the H1 double-beadlock wheel, a 16.5-inch wheel should be avoided completely. This is because of the unique shape of the 16.5-inch wheel. Specifically, the 16.5 lacks what's known as a safety bead around the edge of the wheel. This is the ridge that helps keep the tire's bead in place. Where you can dabble in the 10-12 psi range with a regular non-beadlock wheel doing so with a 16.5 is almost certain to result in a tire dislodging from the rim. The fact that tires are more difficult to find for the 16.5 is making them more obsolete as well
So it sounds like even newer 16.5" rims don't have the safety bead (at least according to Ali Mansour). But also, yes, it does sound like the biggest "safety" issue with 16.5" rims is losing a bead at lower air pressure. Probably not an issue for most trucks, but if you do any trail riding (not just sand), airing down to around 15 psi on a half ton (maybe 20 psi on a 3/4 or 1 ton) will result in a much better ride as well as better traction if it's needed. A 16.5" rim probably wouldn't be a good choice in those cases.
Old Jun 7, 2015 | 12:36 PM
Franklin2's Avatar
Franklin2
They still sell 16.5 inch rims. Here's a link to one at summit racing's site.
http://www.summitracing.com/parts/cl...1208/overview/
If you click on the picture and enlarge it, you can clearly see there is a groove where the bead sits on the outside of the rim.
I am not doubting there are 16.5 inch rims with no beadlocks, but I don't think they can make a blanket statement that all 16.5 wheels do not have beadlocks and thus must be avoided.
Old Jun 7, 2015 | 03:41 PM
JPalmer81's Avatar
JPalmer81
they still sell BFG All terrains in 33x12.50x16.5 or you can put some tire from Interco, they have a very wide selection, just might take awhile to get a full set as it seems they are having trouble keeping up with orders.
Old Jun 7, 2015 | 05:30 PM
82F100SWB's Avatar
82F100SWB
I run 9 psi in my 44's without issue, but I also have an 18" wide tire on an 8.75" wheel... LOL
A 305/70R16 is the metric equivalent of a 33x12.50, 315/75R16 is a 35x12.50.
Non split rim 16.5's are really a non issue other than availability for the average truck owner who runs normal tire pressures. The .5 designator does indicate no safety bead, but, go look at a big rig, you will find 22.5 and 24.5 are the common rim sizes, no safety beads there either
