I'd just point out the reason OFF works in this application is that the "deet" (stuff that confuses skeeters) also dissolves plastic and harms synthetic fibers (Rayon). So be careful inadvertently spraying it on anything else, for example paint or clearcoat.
When I bought my SD, 2 months ago, the dealer polished the headlights.
They are getting murky, already.
I have seen many methods advertised to do the job, which is best?
I used Off on my 2000 F350 headlamps and results were brilliant! I sprayed it on the rag then wiped down the headlights rather than spray it directly on the headlights and risk getting it somewhere it could do damage.
Using Off or any bug spray with Deet or even toothpaste will only be a temporary fix. The Deet will melt the plastic and eventually you will have no plastic left. For a more permanent fix try wet sanding the lens with a fine grit sandpaper a few times. After cleaning the lens then spray a couple of coats of clear coat. A video can be found online, just google "chrisfix headlight"
A lot of the haze is also on the inside of the lens. I used to polish them inside and out with sandpaper or rubbing compound. It was only a short lived, temporary fix, so I just replace them now.
423 reviews on amazon and a solid 4 star product. I used car buffing compound first scrubbing it hard by hand for a good 5 mins and then rinses with water. Let it completely dry and then use the wipe new stuff.. the headlight look like new. there is enough stuff to do 3 and i could have done 4 cars total of 8 headlights, if i had the last one ready to go.
some of the reviews had done updates and over a year still looking good.
I bought the headlight restoration kit, by Sylvania, and had it shipped from Amazon. Works as advertised. I bought it for my minivan, because the headlamps were so hazy that you couldn't see at night. The headlamps look brand new now. I had some of the "magic liquid" left over and I used the wet grit sandpaper and restored the lights on my truck as well. They look brand new.
