Ecu
Old May 24, 2015 | 05:33 AM
Edhill's Avatar
Edhill
Ecu
My 89 f150 6 cyl ecu number is worn off how can I find it?
Old May 24, 2015 | 12:07 PM
Eddiec1564's Avatar
Eddiec1564
Best thing to do is find a pick and pull junkyard and find a truck like yours and see if the ECU is there with the numbers.
What is wrong with the ECU you have or trouble with the truck?
Also which transmission you have? Manual or 3 speed automatic or 4 speed automatic?
Old May 24, 2015 | 12:19 PM
rla2005's Avatar
rla2005
If the Calibration code is still on the b-pillar (door jamb) post it here. Might be able to cross reference for you.
Also post your truck details as posted above.
Old May 24, 2015 | 03:45 PM
Edhill's Avatar
Edhill
Code
E8ae6e061 ahb
Old May 24, 2015 | 03:48 PM
Edhill's Avatar
Edhill
Bad ecu
4 speed starts hard fuel pump does not shut down stutters going down road check ecu looks like it got wet
Old May 24, 2015 | 06:10 PM
subford's Avatar
subford
Originally Posted by Edhill
E8ae6e061 ahb
That is not a calibration number:
A calibration number would be something like "O-98A-R05" as in the photo below.
Old May 24, 2015 | 06:37 PM
Edhill's Avatar
Edhill
Try this
Calibration number
7-51h-r00
Old May 24, 2015 | 07:32 PM
subford's Avatar
subford
The ENGINEERING NO. is what the auto part stores and the salvage yards use and the number that is on the ECU Computer.
The SERVICE NO. or part number is the number the Ford dealers part room uses.
The ECU Computer numbers for CALIBRATION: 7-51H-R00 4.9L EFI is:
ENGINEERING NO. :
E7TF-12A650-K1B, K2B or E8TF-12A650-CL1A, CL2A Alt.
SERVICE NO.:
E7TZ-12A650-KB or E8TZ-12A650-CLA Alt.
Old May 24, 2015 | 07:43 PM
Edhill's Avatar
Edhill
Thanks
Thanks that tell me what I need
agkcpa
Feb 1, 2024 01:29 PM
KalebTalon
May 12, 2011 06:04 PM
Loganwildman
Aug 19, 2007 05:50 AM
FZadra
Mar 18, 2006 09:05 PM
rilgulad
Mar 29, 2005 06:50 PM
