Sponsored by: Real Truck
Squeeky Doors
Old Jul 28, 2003 | 06:09 PM
4byzero's Avatar
4byzero
Unhappy Squeeky Doors
I have a 3 month old F250 Super Cab with squeeky doors. I have tried silicone, door ease and none of these have worked. The dealer could not give me an answer to the problem. When you push on the top of the doors, you can can hear the creeking sounds on the rubber seal of the doors. Does anyone know of a fix?
F250 Lariat 5.4 4x2 camper package 6 speed
Old Jul 28, 2003 | 06:19 PM
xanthias's Avatar
xanthias
Squeeky Doors
Use this board's search function and use the terms "creak" "door" "cab" or "rattle" and you will find several threads that discuss solutions
Old Jul 29, 2003 | 07:31 PM
4byzero's Avatar
4byzero
Squeeky Doors
i have looked and did not find the answer?
Old Jul 29, 2003 | 07:59 PM
FortyFords's Avatar
FortyFords
Squeeky Doors
The fix is to adjust the door strikers a little tighter .
That should fix it !
Or turn up the radio!!!!!!!
you may have to have the doors realigned by the dealer bodyshop!
Rich
Old Jul 30, 2003 | 05:39 AM
4byzero's Avatar
4byzero
Squeeky Doors
thanks for the info i will give it a try when i bring back to the dealer. if it does not work i will turn the radio up.
Old Jul 30, 2003 | 09:40 AM
xanthias's Avatar
xanthias
Squeeky Doors
4byzero, this is the thread you want. I suspect you did not set the date function on the search page to look far enough back:
https://www.ford-trucks.com/forums/s...threadid=17807
Old Jul 30, 2003 | 10:48 AM
narcicus's Avatar
narcicus
Squeeky Doors
I would be careful with making the doors tighter.
I noticed a rust spot on the rubber seal at the top of the rear passenger door this weekend.
Upon inspection it seems that the door may be too tight and has been rubbing when opening and closing, wearing the paint off the door at the top.
But at least they don't squeak
Old Jul 30, 2003 | 07:14 PM
broncodan's Avatar
broncodan
Squeeky Doors
Hey,
Had the same problem....went away on its own after about
6 months!
Dan
Old Jul 31, 2003 | 09:42 AM
kanertop's Avatar
kanertop
Squeeky Doors
I used WD-40 and it took the squeaks away.
1980 Ford F-250
Jul 7, 2012 04:42 PM
Big Red F250 SD
Mar 31, 2010 01:14 PM
denverdave
Nov 26, 2006 08:59 PM
Bernie Lomax
Oct 14, 2004 06:12 AM
sspears
Aug 19, 2000 12:59 PM
