door hinge pins!
Old Jul 7, 2012 | 03:14 AM
1980 Ford F-250's Avatar
1980 Ford F-250
door hinge pins!
I cannot find the door hinge pins anywhere to replave the squeeky ones that seam to get worse everyday!! where can i find them?!
thanks!
Old Jul 7, 2012 | 03:52 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
FoMoCo did not offer door hinge pins for these trucks by themselves, they were only furnished with the hinges. Carpenter has no door hinge pins listed for 1973/79's.
AFAIK, the hinges are not reproduced.
1973/79 F100/880 & 1978/79 Bronco
D3TZ-1022800-A .. Right/Left Upper Door Hinge / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D3TZ-1022810-A .. Right/Left Lower Door Hinge / Obsolete
BELK FORD in Oxford MS has 1 = 662-234-4661.
EARL FLOYD FORD in Carrolton KY has 1 = 800-732-2037.
JST AUTOMOTIVE in Lebanon TN has 1 = 615-443-3086.
NELSON FORD in Martinsville VA has 1 = 276-638-2331.
MATLOCK FORD in Franklin IN has 2 = 600-987-3673.
VINTAGE PARTS in Beaver Dam WI has 2 = 877-846-8243.
Old Jul 7, 2012 | 06:38 AM
Stinky7-11's Avatar
Stinky7-11
LMC has complete hinges upper & lower for 73-79 Bronco & Pick-up in online catalog, page 14, part# upper 49-7260 & lower 49-7262 these are $49.95ea. I have seen replacement pins with bushings I will look again! I am missing a spring in drivers side, hinge is fine, hope this helps. http://www.lmctruck.com/icatalog/fc/full.aspx?Page=14
EDIT***********JBG PIN KIT Door Hinge Repair Kit ***************
Old Jul 7, 2012 | 07:30 AM
Canus's Avatar
Canus
Got my replacement pins and bushings from Bronco graveyard.
Old Jul 7, 2012 | 08:43 AM
PaytonK.79Ford's Avatar
PaytonK.79Ford
I've gotten many things from Bronco Graveyard. Been happy with the service and loved every product I've got. I do most of my business with them.
Old Jul 7, 2012 | 09:04 AM
GOVTMOD's Avatar
GOVTMOD
Someone suggested in the tips and tricks thread that the hinges could be drilled out and Chevy pins installed.
Old Jul 7, 2012 | 09:15 AM
PaytonK.79Ford
If you want to lower the value of a Ford by putting Chevy parts on it!
Old Jul 7, 2012 | 11:13 AM
1980 Ford F-250
Just found them on broncograveyard!!! Thanks everyone
Old Jul 7, 2012 | 04:42 PM
GOVTMOD's Avatar
GOVTMOD
At least someone has found a good use for a Chevy. Make Fords last even longer.
winginit
May 13, 2015 09:13 AM
xcalbr2
Aug 20, 2014 09:41 AM
rocco913
Aug 27, 2010 01:08 PM
E100PU
Mar 11, 2009 10:14 PM
tlolesen
Mar 1, 2009 05:09 PM
