Changing Turbo... plug & play?
Old May 19, 2015 | 10:11 PM
DawnPatrol's Avatar
DawnPatrol
I'll be the first to admit that I am not a mechanic or a certified tech. I can do minor fixes, maintenance things, etc. I have basically paid for a lot of the upgrades on my truck.
If I were to attempt to change out my turbo myself, be it an OEM, or and upgraded aftermarket (I want to run basically stock tune), is the replacement of the turbo basically a "plug & play" issue?
I have had the updated turbo drain installed in one of my previous upgrades
Thanks to all in advance that have more expertise than I do!
Alan from San Diego
Old May 20, 2015 | 06:55 AM
Curt's05's Avatar
Curt's05
Wiser by FTE
The stock turbo would be plug/play. After market you would want to tune it to take advantage of quicker spooling & power.
Old May 20, 2015 | 09:55 AM
9228.bobcat's Avatar
9228.bobcat
If you put an 03 turbo "10" vein, you would want to get a 03 pedistal mount as well. All other oem turbos would be ok.
Old May 20, 2015 | 01:10 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
It's all plug n play. Might suggest a VGT relearn after install, but most likely not needed.
Josh
Old May 20, 2015 | 04:51 PM
npccpartsman's Avatar
npccpartsman
IIRC you can put the 03 turbo on the 04 and up pedestal but you only use the 2 front bolts (all that's really required anyway). You just can't go the other way.
Old May 20, 2015 | 06:12 PM
DawnPatrol's Avatar
DawnPatrol
Thanks to all!
BTW how do you do a "VGT re-learn?"
Old May 20, 2015 | 06:42 PM
npccpartsman
Originally Posted by DawnPatrol
Thanks to all!
Disconnect both battery cables and turn the light switch on for 30 seconds then reconnect. This will clear the KAM (keep alive memory) capacitors and let the PCM "start" again. It doesn't clear the PCM just stored "bad habits".
Old May 21, 2015 | 05:36 PM
DawnPatrol's Avatar
DawnPatrol
Thanks Tim. I am assuming the "light switch" is the headlight switch?
Old May 21, 2015 | 09:21 PM
npccpartsman
Yes, thanks for clarifying that.
4x4countryboy
May 10, 2012 09:02 PM
Sheryle
Nov 18, 2011 01:36 PM
mt96
May 7, 2009 05:39 PM
mike02ss
Jul 11, 2007 05:49 PM
haulingboat
Sep 18, 2006 04:22 PM
