smoke problems
Old May 18, 2015 | 07:20 PM
creather's Avatar
creather
smoke problems
New here. I have a late 99 250. Stage 1 injectors and dp tuner. About 250000 miles. Grey smoke when i take off or just idling but once going down the road clears up. Truck seems like it's running fine no loss of of power or fuel in the oil or oil in water. Thought maybe an injector but they was just replaced and only about 8 to 10 thousands miles if that.. I'm in the fort smith ar. Area wondering if anyone close had an AE scanner near to get it scanned. Willing To meet.
Old May 18, 2015 | 07:31 PM
DieselDenny's Avatar
DieselDenny
Do you have the ability to do a compression test. If it's running fine and your dropping a small amount of oil, I would suspect rings or an injector.
Have you checked blow by?
Denny
Old May 18, 2015 | 07:37 PM
creather's Avatar
creather
No way to check compression. .. what about blow by i don't notice alot smoke coming out there. I did notice smoke coming out near my turbo but checked connections and found nothing loose. Checked blade inside and no up and down slack.
Old May 19, 2015 | 07:30 AM
Tugly's Avatar
Tugly
Do you have a portable device, like an iPhone or Android? If so, you will find countless threads here on OBDII apps and adapters. Much cheaper than AE, just not quite as powerful. The BEST link in my signature has an AE map.
salem747
Jul 18, 2017 10:44 AM
al0311
15
Jan 30, 2016 06:33 AM
gdmafia
Dec 14, 2015 02:30 PM
fl_mudlife
Nov 2, 2011 07:21 AM
unluckylow
33
Jul 17, 2008 09:49 AM
