ECT VS EOT Temp
Old May 17, 2015 | 08:39 PM
OUTLAWSSAA's Avatar
OUTLAWSSAA
Trailering
ECT VS EOT Temp
I have an F350 King dually that I bought new in 2005. I've been reading on here about the 15deg differential between the ect & eot. At 75,000mi I replaced the egr cooler with a Bulletproof cooler and replaced the oil cooler at the same time.At 94,000 I installed a coolant filter. Now at 105,000 I,m getting a PO12F code and the dreaded wrench on the dash. Normal driving it stays around 10 or 15deg difference, but if I start towing or take it to 75 mph it will go to 20-25 dif. There was less than 20,000mi on the oil cooler before I put the coolant filter on. My question is,could the oil cooler be plugged up in less than 20,000mi? Thanks in advance guys.
Old May 17, 2015 | 08:42 PM
mustang_309's Avatar
mustang_309
What do the TFT, ECT and EOT read after an overnight cold soak? Should be within a degree or two of one another. What is the ECT getting up to?
Old May 17, 2015 | 08:59 PM
diesel_dan's Avatar
diesel_dan
You didn't mention much about flushing the coolant system -- a filter is good to put on, but flushing is what really gets the crud out...
It does seem you have another plugged oil cooler....
Old May 17, 2015 | 09:07 PM
OUTLAWSSAA's Avatar
OUTLAWSSAA
Trailering
Mustang,yes after a cold soak they read exactly the same.
Diesel Dan, when I changed the EGR cooler I had the system flushed and put the preferred extended life coolant in it.
Old May 17, 2015 | 09:25 PM
LivingLarge's Avatar
LivingLarge
This ^^^^^^^^^^^^^^^^^^^^^^^^^^^
Old May 18, 2015 | 09:44 AM
TooManyToys.'s Avatar
TooManyToys.
Unfortunately the heat exchanger can start to clog with impurities as soon as the motor is restarted. It extremely hard to get out all of the particles, especially those in the radiator and heater, bypass filter or not. I had a complete rebuilt motor installed on my truck that had an coolant filter installed, used Rotella ELC and still I watched the delta climb in time. And this is with the system completely flushed well over what people do on these forums a few thousand miles before the original motor failed.
A coolant filter helps but is not a perfect solution. The heat exchanger turns out to be a very efficient coolant filter.
rtwilliams
Jan 12, 2014 03:32 PM
robert421960
Aug 25, 2011 07:49 PM
U.P. Builder
Aug 22, 2011 04:02 PM
woodlander
Oct 15, 2010 02:00 PM
usmc161
Jul 14, 2010 09:31 PM
