Frame Restoration
Old May 15, 2015 | 12:56 PM
Cdavis9's Avatar
Cdavis9
Frame Restoration
I have a 1991 f250 frame I was planning on sandblasting and painting. I want to use POR-15 is there anything I should watch out for or do before I paint it? The frame is going to be for my 93 f150. I've heard you should paint over the POR what paint did you use?
Old May 15, 2015 | 01:40 PM
Mike1's Avatar
Mike1
Well, from what I've been told, you don't need to sand (soda) blast a rusted frame with POR15. It is designed to be sprayed right over the rust and whatever chemical is in it supposedly stops further oxidization. POR 15 is designed to be the coating, the paint, that is exposed to the air, supposedly it actually gets stronger if you DO NOT paint over it.
Old May 15, 2015 | 04:48 PM
Fastback460's Avatar
Fastback460
If you're sandblasting, I don't think you need to do any other prep work. And sandblasting is the best way to go.
According to the website for POR-15 you should topcoat if it will be exposed to sunlight, because the UV rays will break down the POR.
When I get mine done I will be using
Valspar Tractor paint Valspar Tractor paint
. I've seen some really good results with other people using it.
Old May 15, 2015 | 04:54 PM
andym's Avatar
andym
POR stands for Paint Over Rust. Sandblasting and using POR doesn't make sense.
Old May 15, 2015 | 05:03 PM
FORDF250HDXLT's Avatar
FORDF250HDXLT
that's what i was going to say as well.if your doing the best prep possible (sand blasting) then don't bother using a paint designed to paint over rust.use a quality primer/paint of your choice.
i like that valspar enamel as well.im having my commercial wood chipper fixed up/welded/other fixes and finally going to have it sand blasted.im thinking of bed liner on the thing to hide all it's imperfections.
Old May 15, 2015 | 05:06 PM
Fastback460
But even if you are sandblasting wouldn't POR still give better rust protection than a standard primer/paint?
Old May 15, 2015 | 06:15 PM
Diesel_Brad's Avatar
Diesel_Brad
Yes, FAR SUPERIOR results than painting over rust.
I have done this on quite a few trucks
1. strip chais as much as possible
2. sandblast to white metal
3. spray POR15 as a primer
4. while wet topcoat with chassis black
Old May 15, 2015 | 06:32 PM
'89F2urd's Avatar
'89F2urd
does anyone know what ford uses on their new trucks for frame coating, and if they sell it?
that stuff seems to be the best frame coating ive ever seen, of course time will be the only way to tell. stuff is rock hard.
Old May 15, 2015 | 08:08 PM
Fastback460
Thank you, that's what I thought.
Old May 15, 2015 | 09:18 PM
Cdavis9's Avatar
Cdavis9
I may ask dumb questions but that is exactly why I ask them
Old May 16, 2015 | 07:25 AM
Diesel_Brad
Typically Cosmilne and a power washer takes it off fairly easily
blk450er
16
Sep 10, 2017 11:43 AM
John - NNY
23
Oct 16, 2007 05:01 PM
1978fordf250
Paint & Bodywork
Apr 20, 2004 10:40 PM
hell on wheels
Paint & Bodywork
Oct 2, 2003 04:33 PM
85351ho
May 1, 2001 04:55 PM
