Paint, Powdercoat or POR15?
Received 1,369 Likes
on
The rust inhibitor products (POR-15, Rust-Bullet, etc) are better suited to rusty metal (imagine that!), and bond chemically to the ferrous oxide (rust). If the frame is not rusty, and assuming that it is in bare metal, then you are better off spraying a coat of metal etching primer followed by a good coat or more of catalized acrylic enamel paint.
on
I used POR-15 on my frame and I'm very happy with it...so happy, in fact, that I will never use anything else. Yes, it's messy and if you get it on your skin it will have to wear off but you can save so much work by just wire brushing the frame instead of sand blasting it that it makes it worthwhile. I have had powdercoated lawn furniture that rusted after awhile so I am not impressed with powder coating.
on
problem with powdercoat is that there is no primer used before you powdercoat. so there is no rust protection if you get a chip and on a frame if you are going ot drive it at all, will get lots of rock and gravel chips all over the place. powdercoat is tough, but it will chip.
i owuld save powdercoating for the pieces that aren't exposed to rocks and such, like brackets, valve covers, air cleaners etc.
rgds
Mike
rgds
Mike
Had the frame on my 40 Sedan undercoated and put 40,000 miles on it over about 6 years. Looked as good when I sold it as it did when I put it together. I sprayed my F100 with Eastwood Chassis black primer and top coat. While assembling the chassis I chipped it a few times by dropping/hitting it with wrenches atc. I am currently working on my 40 coupe with a powdercoated frame and am not aware of chipping it during assembly. I will also powdercoat the next one. Joe
Originally Posted by mcdonaldm
problem with powdercoat is that there is no primer used before you powdercoat. so there is no rust protection ....
I used POR 15 on my sandblasted frame; have not subjected it to weather yet. I have had to due touch-ups since coating with POR; used a tremclad product over the POR, which immediately wrinkled; would not bond. so I will have to sand off the areas, and apply another coat of ??; not sure, looking into alternates that will adhere to POR.
Tom
Tom
