How to install a Brake Controller?
Old May 15, 2015 | 01:30 PM
SoCalAngler's Avatar
SoCalAngler
Originally Posted by subford
The 92 had a 4pin plug and the 95 had a 6pin plug. That is the difference.
The 1992 Brake Controller and trailer plug wiring:
I currently have a trailer plug under bumper. It appears to be factory as it had the Ford logo. I had to change it out to the RV 7 flat blade type socket as it was a 7 pin round type. The 7 pin round that I replaced had the Ford logo.
I also have an RV 7 blade flat socket in truck bed near left fender hump as original owner had an overhead camper and I assume used this plug for camper electrical hook up.
1. So, with my 1992, what will I have under my dash?
2. Which Tekonsha adapter will work for me?
3. Will I have to run anything from battery or fuse box for brakes?
I'm a little confused on how to wire up this controller and have never had to hard wire one of these....as my previous trucks were newer and were plug and play type.
Thanks!
Old May 15, 2015 | 01:58 PM
subford's Avatar
subford
A 4 pin plug that will mate with the plug in post #7 above. This is called connector C210.
Use the one in post #7 above.
You can buy the plug at Advance Auto parts:
http://shop.advanceautoparts.com/p/h...ntent=10711125
Here is an image of a Hopkins #47695 plug:
3. Will I have to run anything from battery or fuse box for brakes?!
No if it is factory trailer wiring you will not have to run any wires under the truck or do any wiring at the back.
Here is a PDF for the wiring:
http://www.carid.com/images/hopkins/...structions.pdf
The wiring to the plugs at the controller should be something like the below diagram.
The black dots are the but connectors in the post #7 above.
Not that diagram is for a 6pin C210 but just look at the wire colors and not the numbers.
Old May 15, 2015 | 02:24 PM
sgip2000's Avatar
sgip2000
Weird. Tekonsha said mine took the "6 pin" but the pins didn't line up. The four pin fit into the 6 pin socket though. Mine also had a dealer installed Tekonsha Voyager installed.
Anyone know when exactly the plug was changed?
Old May 15, 2015 | 03:35 PM
SoCalAngler
subford.....Thanks for the clarification
1. How do I know if I have a factory installed trailer towing/wiring option?
2. Is it possible to have the factory trailer towing wiring package and not the larger radiator and trans cooler I have read about?
The reason I ask is because I do not have an OEM trans cooler nor do I believe my radiator is "extra large"
Thanks
Old May 15, 2015 | 04:53 PM
GuitarJesus's Avatar
GuitarJesus
Hey SoCal, what model and size 5er did you get?
Old May 15, 2015 | 05:14 PM
SoCalAngler
picked up a 1998 Jayco 243RKS. It's older and small but has a queen bed up front, dinette, jack knife couch and nice rear kitchen. One original owner and he kept it very clean. Easy to tow, can fit into any state park, and it was not too expensive!
Old May 15, 2015 | 07:18 PM
subford's Avatar
subford
If it has the towing package it would have the extra relay box mounted on the side of the fuse/relay box as in the photo below.
Maybe, but it depends if it was special ordered and what they ordered. I will guess that you could just special order the trailer wiring by itself.
But I would think to be very rare.
Old May 15, 2015 | 09:44 PM
SoCalAngler
Below are pics of the relay box I have.
It has what appears to be two blank sections and one "Back up Lamp Relay," and one "Charging Relay."
What does this mean?
Old May 16, 2015 | 07:13 AM
subford's Avatar
subford
It means you do have the factory wiring going to the rear of the truck and the blue wire running all the way from the C210 plug to the rear of the truck.
This is called "Trailer/Camper Adapter" in the wiring diagrams.
But it could also mean that someone added the relay box and did their own wiring for the trailer plug wiring.
Old May 16, 2015 | 10:32 AM
SoCalAngler
subford....Thanks for your input and pics! Your assistance is greatly appreciated! This is great news.
mmastroianni
All Things Towing
Jul 24, 2012 09:29 AM
ericcoplan
Apr 29, 2011 12:07 PM
jb9339
All Things Towing
20
Feb 27, 2008 12:16 AM
smokewagun
2004 - 2008 F150
May 18, 2006 10:43 AM
TheSpank
All Things Towing
Sep 25, 2003 01:11 AM
