Sponsored by: Real Truck
Brake controller question
Old Mar 18, 2011 | 11:15 PM
ericcoplan's Avatar
ericcoplan
I'm sorry if this is posted elsewhere on this site but i did a search and could not find it.
I have a 2006 F250 PSD. There was a wiring harness provided with the truck for hooking up a brake controller which i am trying to do.
My issue is the the description for the factory wire harness leads do not match up with the aftermarket brake controller.
Ford OEM wire harness has four wires
1- Trailer electric brake feed(I assume goes back to the trailer) DBlue
2- Ground(no assumptions needed) W
3- Trailer brake control feed(I assume hook up to battery + on controller) R
4- Stop lamp feed to brake control(I assume to brake pedal stoplight on controller) LGreen
Aftermarket brake controller
1- Battery+(hook up to 3 i think) Black
2- Stoplight(hook up to 4 i think) Red
3- Ground-(hook up to 2 I'm sure) white
4- Brake(Hook up to 1) blue
Any insight would be appreciated. I feel like i am making a simple thing difficult but I hate diving in shallow pools
Old Mar 18, 2011 | 11:32 PM
TexasRebel's Avatar
TexasRebel
if you have any doubt... put a multimeter to the pins on the truck side...
one will show 12V with ignition...
one will show 12V when you step on the brake
one will have continuity to ground...
one will have continuity to the 7 pin at the rear...
Old Mar 19, 2011 | 09:04 AM
Bigpipes 35's Avatar
Bigpipes 35
Or if you got a tekonsha prodigy you dont have to do any wiring , you get the harness made for your truck and simply plug it in
Old Mar 19, 2011 | 12:13 PM
bunklash's Avatar
bunklash
What Bagpipes said. My experience has been you have to buy the pigtail for your model controller to match Ford's plug.
It sounds to me the harness you have was meant for a different model controller. As far as I know, the truck will come with the plug for a harness, but not the actual harness.
BTW, welcome to the forum. Stick around and be amazed. Some terrific people and info to be found here. Good luck!
Old Mar 19, 2011 | 12:24 PM
Kajtek1's Avatar
Kajtek1
Buying ready harness is the option, but those things can cost more than a case of beer for just few wires. The way I see it,
blue goes with blue,
white goes with white
red goes with black
green goes with red.
Another indication is wire size. While power feed to the controller and out to the trailer brakes are heavy wire, the stop light wires are much smaller.
Old Mar 19, 2011 | 12:45 PM
TexasRebel's Avatar
TexasRebel
On pickups without the iTBC, ford supplies a harness that plugs into the truck, but has four blunt cut wires on the other side.
Many brake controllers do not have a harness type connection... they just have four wires coming out of the back.
Old Apr 29, 2011 | 12:07 PM
oconnekp's Avatar
oconnekp
Yeah I agree with Kajtek1 on the wiring.
I have a 2004 f250 that is wired exactly how he explained it. Mine is a tekonsha and I do have the plug for it but it came wired without it.
72Blazerod
Aug 7, 2013 04:32 PM
metriccar
Apr 25, 2012 11:05 PM
tettnanger7
All Things Towing
Sep 21, 2009 03:04 PM
jump05powerstroke
Aug 20, 2008 10:50 PM
FordTrucksKickGM
All Things Towing
Jan 9, 2008 03:25 PM
