Rod Knock???
Old Aug 22, 2011 | 04:45 PM
The Boss's Avatar
The Boss
Rod Knock???
My buddy has a beautiful 2005 F-350 Super Crew SRW with the 6.0 Powerstroke and just under 100,000 miles on it. Coming home from the Carolinas this past weekend he started blowing smoke & had a noise......this is what it looks like.
Rod knock? - YouTube
So what's the diagnosis Doc?
Old Aug 22, 2011 | 04:54 PM
wulfman's Avatar
wulfman
I am no expert but i don't think its a rod knock. Maybe injectors they can make some funny noises , but all that white smoke could be EGR cooler blew and maybe dumping water in intake , then you can guess where it goes next. JMO
Old Aug 22, 2011 | 04:56 PM
wulfman's Avatar
wulfman
Oh does the smoke have a coolant smell or does it smell like fuel.
Old Aug 22, 2011 | 05:07 PM
The Boss's Avatar
The Boss
He dropped it at the dealer and they replaced the EGR cooler & the pump. But the noise is the same and the smoke is still there - same as when he was driving. Under load the noise goes away, when he takes his foot off the pedal & coasts or idles it comes back.
He put around 200 miles on it like this - I don't see any rod flopping around for that long without seizing the motor. What else could it be?
Old Aug 22, 2011 | 05:08 PM
The Boss's Avatar
The Boss
He's going to stop at the dealership tonight and check the smell.
Old Aug 22, 2011 | 05:15 PM
ljutic ss's Avatar
ljutic ss
Could be an injector knocking, tell him to check the dip stick for an increased level of oil which could be diesel fuel building up.
Old Aug 22, 2011 | 05:32 PM
cheezit's Avatar
cheezit
sounds like a broken rocker to me...
Old Aug 22, 2011 | 06:05 PM
The Boss's Avatar
The Boss
Just a coincidence they both happened on the same trip? or would one trigger the other?
Old Aug 22, 2011 | 06:06 PM
cheezit's Avatar
cheezit
get enugh water in a cyclinder and things can happen
Old Aug 22, 2011 | 06:42 PM
2006powerstroke90's Avatar
2006powerstroke90
Excuse my ignorance...The dealer Fixed the EGR cooler...what pump?
Anyways, they let it go back out with it still smoking and knocking?
Could it be possible, the injector tip broke off? and its slapping around in there?
Here is a video of my injector knock......
Notice the smoke, my egr cooler was also bad, and 2 injectors went at the same time..Doesnt knock as long as yours, but you can hear the sound
This is what my 2 bad injectors looked like obviously extremely black and you cant even see the colors of the o rings anymore
Old Aug 22, 2011 | 06:51 PM
cheezit's Avatar
cheezit
fuel knock is also possible though.
Old Aug 22, 2011 | 07:39 PM
The Boss's Avatar
The Boss
The dealer hasn't let it go yet, they want to get more money out of him first!
The knock is steady, like you heard but the smoke is just like yours and when I just spoke to him he said the exhaust smells like fuel, not sweet like anti-freeze.
Old Aug 23, 2011 | 01:29 AM
matty169's Avatar
matty169
Cracked nozzle......
When you rev it up to about 2-2.5k does the knock sound better? You have a cracked/broken nozzle. I will bet on it. And if I am correct and he is driving it, he WILL melt a piston if he hasnt already. Unscrew the oil fill cap at idle. Got pressure coming out??? Puff, puff, pufff,???? Thats bad.
Old Aug 23, 2011 | 05:40 PM
The Boss's Avatar
The Boss
Is there a way to test the injectors?
Is it likely an injector would fail as a result of the EGR cooler failure?
Old Aug 23, 2011 | 08:24 PM
The Boss's Avatar
The Boss
He said when he took off the oil fill cap there wasn't any puffing - just revving the engine only made the knock go faster - it didn't go away. It did go away under load when he was on the highway the other night however.
