pulling hard to the right
Old Jul 28, 2003 | 09:57 AM
tojoski's Avatar
tojoski
after doing a PS conversion, my 66 pulls hard to the right
I am using a PS pump from a 74, and a gearbox from a 72...
and it seems that when i rev the engine at standstill, the wheel tends to jerk to the right
the PS pump growls and groans at anything over 1500 RPM, coulld this be caused by the pump or the gearbox?
help!
Old Jul 28, 2003 | 03:48 PM
barry's Avatar
barry
If your pump is good, the growling is caused by air in the system. You have to "bleed" the system by turning back and forth the steering wheel until the noise goes away. Add fluid to keep it full. If not, the pump is bad. I have a 89 F-250 and I've had the growl in mine for 6 years. As far as the pulling, I would make sure the s/box isn't adjusted too tight. That causes the steering to pull to one side.
Old Jul 28, 2003 | 03:59 PM
tojoski's Avatar
tojoski
how do i adjust it?
I have never had to do that
Old Jul 29, 2003 | 08:51 AM
William's Avatar
William
Bleed the system first! Raise the front of the truck, start the engine and turn the steering wheel all the way left, then right several times. Add fluid and repeat until the steering turns smoothly without any noise from the pump. Pulling may be caused by low tire pressure, steering alignment or hanging brake caliper. Check all this out ASAP! Adjusting mesh load on the gear box is not difficult but requires an inch pound torque wrench and disconnecting the pitman arm at the gear box. Try the other stuff first and post back. The tech section has an article on this mesh load business.
Old Jul 29, 2003 | 11:04 AM
tojoski's Avatar
tojoski
ok
i don't think there is air in the pump, i have turned it alot and the fluid hasn't gone down and the growling continues
i adjusted the gearbox and it helped a little, but the wheel is easier to turn to the right than the left
and with the truck jacked up, the wheel will turn to the right then i rev the engine, is the gearbox worn out too? maybe someone made all right turns in the donor truck
Old Jul 29, 2003 | 11:36 AM
William's Avatar
William
Man I hate it when this happens! Have you been driving this truck? I ask because sometimes Junk Yard boxes have been sitting a while and the hydraulic valves in them are screwed up (sticky) and driving may loosen them. There is a process to center the steering control valve but I haven't done this in years and I'll need to look in the book. If the pitman arm is disconnected can you move the wheels by hand lock to lock (aganst the steering stops)? The noise is I suspect is the pressure relief valve in the pump. Sometimes a complete fluid change helps to clean and flush out crap. You need to figure this out before you drive the truck. I'll look in the book when I get home this evening.
Old Jul 29, 2003 | 11:56 AM
tojoski's Avatar
tojoski
i have driven the truck a little, not much though
but he donor truck had sat up for atleat 10 years, as the motor was blown up in it.. the wheels move freely from right to left
i haven't tried purging the fluid, but i did run about 2 quarts through it before i ever started the engine
another thing, i am using the power steering fluid like you get at autozone, should i try some ATF?
Old Jul 29, 2003 | 12:26 PM
William's Avatar
William
10 years is a long time. I'm guessing the valves in the gear are stuck. Flushing with ATF might help, but the fluid from auto zone is allright. I usually core these gears to avoid the situation you are in. They cost about 150 bucks but that thing is so heavy I try to install it once and never screw with it again. I usually over do this stuff but I think its worth the extra money. I core everything on disc/power steering conversions. Wish I could be more helpful. I'll check the book tonight.
Old Jul 30, 2003 | 08:11 AM
William's Avatar
William
I checked my Chiltons for 71-78 Fords. Honestly, overhauling the steering gear is complicated and special tools are required. I recommend you replace the gear. The Junk Yard may let you swap it for a good one. Try to find one that has not been sitting. Wish I had better news!
idfliers
Aug 23, 2021 05:52 AM
ljcandme
Aug 23, 2011 11:48 AM
34ford
Aug 12, 2008 04:43 PM
RawPower
Jan 28, 2005 08:34 AM
smile4you84
Dec 29, 2003 05:14 AM
