ignition help needed
Old May 19, 2015 | 04:38 PM
  #31
peka's Avatar
peka
it runs
Started right up, put new voltage regulator and battery in. Voltage at coil with engine running is 10.85 How big of resistor will I need to bring it down to 9 volts?
Old May 19, 2015 | 04:59 PM
  #32
JimsRebel's Avatar
JimsRebel
Are you measuring the 10.85 volts across the coil or is the negative meter lead on the battery post negative and the positive meter lead on the coil positive.
Also, try another voltage check, KEY ON engine not running, coil positive and battery terminal negative.
Jim
Old May 19, 2015 | 10:32 PM
  #33
peka's Avatar
peka
This 10.85 was coil + and ground, engine running, with battery - and coil + and engine running it was 10.65. Engine not running, key on and coil + and battery - is 6.55
Old May 20, 2015 | 11:40 AM
  #34
JimsRebel's Avatar
JimsRebel
While your voltage readings aren't exactly what I was expecting I would still put it in the safe zone, I would just run it as is.
As an added tip I would mount the DS2 IGN module with a few washer between the plastic inner fender and the IGN module box. This will allow air flow under the box and aid with cooling the IGN module.
Jim
Old May 20, 2015 | 01:20 PM
  #35
peka's Avatar
peka
Already did that plus added a ground wire from firewall to ignition box.
tlb
Jun 3, 2017 04:35 PM
abe
Jan 1, 2013 04:51 PM
JimG1098
Jan 13, 2008 11:34 PM
Pony Power
Electrical Systems/Wiring
Jul 27, 2006 09:43 PM
MercM47
Mar 2, 2005 11:05 AM
