ignition help needed
Are you running this through one of your ballast resistor? Which one?
RU4 resistor that measures 2 ohms and a RU11 that measures .5 ohms
Jim
FWIW IMO 1.2 is just fine, I do not use a resistor in my truck and use a low .45 ohm resistance coil. Primary resistance is a performance vs. component life equation. If you want a better chance of the coil and box lasting a long time have as much as 3 ohm total. With my .45 ohm total though I haven't killed a cheap box in many years. Points systems had about 3ohms for a V8, a DSII can handle less.
Condition: KEY ON engine not running, DS2 ignition module, .45 ohm coil
12 volts divided by .45 ohms will give you 26.6 amps of current
Stock would be in the 4-5 amp range.
Jim
I found this on another forum,
The manufacturer specifies a primary resistance. That is the sum of the coil resistance plus the resistance of the much understood "pink" wire. The primary circuit resistance should not be less than the manufacturer's resistance. Guys go less and burn up coils for hot spark. Guys go more and end up with misfires.
The stock truck wiring has a splice on the left inner fender ... S216 ... on the wiring diagram in post 9.
If you are downstream of that point you wont need to add a "start wire"
Jim
Are you using a DS2 IGN wiring harness from an older truck?
If you don't have the harness for coil power, it's not an issue since the only other wires in this piece of harness are for the gauges and they will still function correctly with the original harness. Just swapped over my father's '85 302 this weekend and only had the distributor harness myself. As everyone has mentioned the resistor wire is there. It's the fat red with green stripe wire on the left fenderwell and it is changed to a smaller brown with pink stripe wire after the connector. Just cut the brown/pink wire, connect a splice to it, and run it to the DSII coil positive.
Conversely, you can also just cut and safety the resistor bypass wire which is white with blue spots. It's spliced into the brown/pink wire about halfway down the harness so you have to remove the tape to get to it. Also, at that point the brown/pink wire changes to white/blue and goes to the TFI coil. Then you can just use the white/blue wire straight from the TFI coil although it most likely won't reach the DSII coil without an extension if you put it on the right side of the engine (I had the full bracket so mounted it with a bolt on the vacant air pump bracket, old coil wire reached then...couldn't use the factory spot due to the EEC temperature sending unit in the heater hose fitting blocking the space). Also if you pull the computer harness out like I did you wouldn't want to bother doing this although you need to unwrap and rewrap that harness to clean it up to retain the gauge wires and new coil wire . I just posted it since I was curious as to where the bypass splice was and took the harness apart anyway.
If you have absolutely no harnesses the job is still very easy as it's only a few wires to splice anyway. You just have to cut the plug off the DSII distributor and splice in the three wires from the TFI harness that will now be hooked up to the DSII module and hook up the coil negative. The wiring is easy to figure out with something like this:
http://www.painlessperformance.com/Manuals/30812.pdf
All in all the job was as easy as everyone says it is....I removed all the old vacuum hoses, plugged the EGR by bolting on an older one (original pintle style seemed to be leaking), and removed the computer harness but cut it off at the firewall to keep from having to plug the empty hole. If you do this, disconnect battery ground first since you need to pull the EEC power wire off the starter solenoid. Even got the old vacuum operated A/C idle kick-up solenoid working buy reusing one of the old vacuum solenoid switches on the valve cover and wiring it to the low pressure switch.....couldn't tell by the drawings if it was computer controlled or not before as the drawings only showed four vac solenoid switches and all of them were connected to the computer.
