Sponsored by: Real Truck
Battery light
Old May 9, 2015 | 07:58 PM
Vinford's Avatar
Vinford
Battery light
2005 F-350 6L diesel
Put new batteries in it a week ago.
Been running good then the radio quit a couple of times. It came back on after truck was restarted.
This morning I go to town and the battery light comes on. I stopped and started about 5 times and on the 6th it wouldn't start.
I got a boost and started home it , started to try and quit when I was almost home.
Was so dead the power windows wouldn't even work.
Have it on the battery charger now and it starts right up but the battery light is still on and the ABS light is on.
Any ideas?
Old May 9, 2015 | 08:11 PM
senix's Avatar
senix
Dead alternator.
Old May 9, 2015 | 08:20 PM
Vinford's Avatar
Vinford
Originally Posted by senix
Dead alternator.
Any way to test?
Old May 9, 2015 | 08:22 PM
senix's Avatar
senix
Yes, most auto parts stores can test the charging system. They can with the tester command the output.
Old May 9, 2015 | 08:52 PM
Vinford's Avatar
Vinford
Thank you
Old May 12, 2015 | 12:43 PM
droldsmorland's Avatar
droldsmorland
Was it a bad alternator? Please follow up when you find the fix.
I see your a regular poster so I probably dont have to go into the rant about making sure all connections are clean and tight to and from the batteries, starter and starting system???
Old May 12, 2015 | 09:50 PM
texastech_diesel's Avatar
texastech_diesel
Token Redneck
He swapped the alt:
https://www.ford-trucks.com/forums/1...l#post15342423
99% of the time a battery light on 6.0L = dead alternator or crispy batteries. Solutions:
https://www.ford-trucks.com/forums/1...ernatives.html
https://www.ford-trucks.com/forums/1...epair-com.html
dblott1
Jan 5, 2015 04:40 PM
koski19
Apr 8, 2013 11:19 AM
SCOTTY STA-28
Sep 22, 2009 12:01 PM
live2hunt
Aug 30, 2007 11:31 PM
