Simple Green?
Has anyone ever seen this or done this? There are quite a few different ways that I came across.
Manufacturer cleaning solution
Dawn
Simple Green
Oxy Clean
To name a few.
My next question would be would you use any of the other methods besides using what the manufacturer suggest?
My experience anyways. To me not really worth the trouble. Speaking of which I need to clean the darn thing again.
I think I'll stay with the OEM filter and leave the Simple Green to cleaning the wheels
I would recommend K&N's cleaner first. It does a fine job and is formulated for their filter oil (which I assume you use). I would skip anything that requires excessive rinsing to get the suds out and that would be any dish or laundry soap, or even simple green (which is actually pretty harsh). I ran K&Ns in a couple of street vehicles and then on some track cars (the latter being the only place I'd use one today).
Now back to the train, which I am on board as well: I think that without running a supplemental foam filter skin over an oiled gauze type filter, you without a doubt are running dirt into your turbo/engine. I've suggested to many doubters that all they need to do is take the non-foam covered filter, brand new out of the box even, with oil on it, and go out in the bright sun. Look up through the filter at the sun. See all those pin-points of light? That's why...
In addition to that I've seen a number of manufacturers that call their intake a "cold air intake", yet they have a pleated cone-style oiled gauze filter in the engine bay. Where exactly is the cold air coming from? Truth is: it isn't getting any "cold air". The factory filter/intake on the other hand IS a cold air intake and dyno tests show you have to put out significant more power to make it be a limiting factor.
CAIs are money makers for their sellers, and that is about all they are...
Long story short. Look around for an OEM for about a month. Different clubs, dealer, ebay, craigslist etc... Didn't find any at all and at the time the dealer was talking 500 bucks for everything back to stock. Got a deal on the Afe that's in my sig for half the cost. Sold the K&N on eBay and was only out of pocket about 65 bucks. I'd still like to have an OEM unit for my truck but still seem to be far and few. If I remember my year truck has to be an 05 to 07 to fit correctly if I remember? I was only seeing 03's 04's.
I was just about out of cleaner for my Afe when I did a search on Youtube and found the additional info on how to clean the oil filled filters. I've been running this setup for almost 3 years with no problems as of yet. Using the sock option is definiely the way to go for added protection. Just checked and got one on the way. The same intake I bought 3 years ago is 110.00 more now
I think there's a less harsh Simple Green formula out. If I was to try this I do some more checking A gallon of SG is 10-12 bucks and would last 20 times over buying the Afe cleaner.
There's always more than one way to skin a cat and the question is now. How will the cat react to a different cleaning solution?
In any case. I appreciate all the replies.
Thx
Thx
If you have an Ebay account just set up a search and have it Email you the findings.
Sean
