2000 V-10 shake on acceleration
Old May 8, 2015 | 12:43 AM
Ardiemus's Avatar
Ardiemus
Well, I have been through the tech folder and all over the forum reading but cant seem to come up with a good first step. When i accelerate the truck shakes, by the sound it seems that its missing a cylinder. I guess it could also be the motor mounts. Besides replacing the plugs and coils, is there something else that could remedy a misfires or dead cylinder?
-Jonathan
Old May 8, 2015 | 01:45 AM
robert_l_ross's Avatar
robert_l_ross
99% it will be a coil...
Old May 8, 2015 | 05:50 AM
RCKYMTN-PSD's Avatar
RCKYMTN-PSD
My V10 started a shake or more of a heavy vibration when it lost a balance weight off of the flexplate -or flywheel
Old May 8, 2015 | 08:09 AM
projectSHO89's Avatar
projectSHO89
...and its associated plug.
First step is to read the Mode $06 TID$53 data with a scan tool and see which CID$ values are non-zero. That will tell you which cylinder(s) to focus your effort on to resolve the problem. Otherwise, you're left with simply replacing everything and hoping you got the problem via the shotgun approach which is expensive and not always successful.
Old May 8, 2015 | 08:13 AM
projectSHO89
I guess that makes you a "1 percenter"!.
Old May 8, 2015 | 11:49 AM
Ardiemus's Avatar
Ardiemus
1,4,8,9 cyl misfire
Well I got the P0301 304 308 and 309 code. I didn't think it was misfiring on four of the 10 cylinders based on that I'm going to have a tuneup done I just don't have the time with family in town and a new baby to do all this I'll let you guys know what they find
Old May 8, 2015 | 11:51 AM
LivingLarge's Avatar
LivingLarge
Clean those injectors
Old May 8, 2015 | 02:12 PM
Ardiemus's Avatar
Ardiemus
#4 Coil Bad
coolant leak on #4, and a bad coil. We'll see how she drives after a good tune up and giring on all cylinders. New motorcraft plugs for the whole engine.
Bowhunter2001
Modular V10 (6.8l)
40
Nov 16, 2013 09:37 PM
az_r2d1
Arizona Chapter
Jun 11, 2013 04:21 PM
Loopy
Modular V10 (6.8l)
May 2, 2013 04:02 PM
papa murph
Dec 20, 2008 02:11 PM
Bigmark'sblownv10
Sep 10, 2004 07:02 AM
