Issues on 2001 Ford F250 - Slight bucking under load
I have a 2001 Ford F-250 5.4L V8. 117,000 miles. The problem I have been relentlessly trying to diagnose is a slight bucking that occurs under load when the truck is in overdrive. When the truck bumps up to higher RPM's it is fine but when it is around 1500-1700 RPMs on the highway it does a small buck like I'm hitting a bump in the road. I know there are many threads on this but none of them have gotten me any closer to a resolution. It also seems to have a bit of power loss when accelerating.
Things I have done so far.
-Spark plugs and COP replaced about 1000 miles ago
-New fuel filter
-Cleaned MAF sensor
-Cleaned throttle body
-New PCV
-Seafoam treatment in gas and through brake booster.
Any other suggestions?
Alex
-New fuel filter
-Cleaned MAF sensor
-New PCV
Alex
When you say "No Codes" is it because you hooked up a code reader and it said no codes? There could be codes stored even without the CEL lighting up. Maybe P0401 or P0402.
Alex
This afternoon I was exploring the idea that it might be a vacuum leak. While I was up in the engine bay I was throttling up the car manually and noticed that there was a loud sucking sound coming from the throttle body area as I gave the truck gas. Anyone know what this could be? Maybe a bad throttle body?
You have a mild misfire, an extremely common issue on the modular engines. You need to use a scan tool to go into the Mode $06 data and look at the individual misfire counts to pinpoint the offending cylinder(s). A simple code reader isn't going to be useful. Without knowing which cylinder(s) to focus on, you're left with simply throwing parts at the problem and hoping you get lucky (you didn't).
See this thread, ignore all the little side detours. https://www.ford-trucks.com/forums/1...bd1-obdll.html
1. Lugging up a hill with light throttle in overdrive
2. Just up-shifted to overdrive as the speed passes through 45-55 mph.
3. Towing heavy, especially in overdrive,
That is why it is critical to DO THE DIAGNOSTICS. They eliminate extraneous concerns and help you focus on the actual symptom(s).
Here's an excellent video from Wells:
Could be normal, we have no way of hearing what you're hearing.
I was able to get ahold of the previous owner and he said the shop he went to used Ford Coils and NGK Plugs. Since im only replacing 1 plug and 1 coil do I need them to match the current setup? If so where is the best place to get Ford OEM plugs other then the dealership.
