General Automotive Discussion
DIY Oil Change
Old May 4, 2015 | 10:49 AM
WaldorfMDGuy's Avatar
WaldorfMDGuy
DIY Oil Change
Hi Everyone,
I have always wanted to do a DIY oil change and I think I'm going to go through with it.
I have been doing my research. Familiarizing myself on the importance of an oil change (see below), researching ect.
Oil Changes Waldorf, MD | Waldorf Ford
I wanted to reach out to you guys and see if you have any useful pointers/tips?
Much appreciated!
Thanks!
Old May 5, 2015 | 06:44 AM
JWA's Avatar
JWA
There's not a lot to this but it would be helpful knowing more about you; skill level, tools available, place or facility where you'd be doing this----things of that nature.
The process is fairly straight forward and doesn't require too many tools. Oil filter removal wrench, oil pan drain plug wrench, catch pans for waste oil and filter, waste oil recycling container and plenty of clean up supplies should an accident happen.
If you're so very new to this project check around on YouTube for a few in structural videos---that would be a good beginning.
Ask anything you want to know---most of are here to help any way we can.
Old Apr 9, 2026 | 08:41 PM
drew999999's Avatar
drew999999
Add another Fumoto drain valve customer to the list. I stick A 5gal blue Kerosene can under and flip the valve open. While its draining, punch a hole in the filter with an awl and let it drain in a small bin and take a walk. Come back and swap the filter, change the filter, hit it with some brake clean, and drag everything out. Fill 'er up and done. Takes maybe 30 minutes tops. I don't have a Tremor, so I do drive up on some 2x8 blocks that lets the everything clear, so that adds a minute or two to the process. I've never had a vehicle that oil changes were this easy. I like using the blue Kerosene cans since it's easy to dump at my local drop off. No splash and easy to pour.
Old Apr 18, 2026 | 01:19 AM
CathedralCub's Avatar
CathedralCub
FTE Community Team
Looks like this thread is over ten years old. @WaldorfMDGuy, I'm curious how it went!
Old Apr 30, 2026 | 11:50 AM
slowmans's Avatar
slowmans
Post deleted....
Tom
2009 - 2014 F150
38
Oct 8, 2013 09:35 AM
mcallister
6.7L Power Stroke Diesel
Feb 17, 2013 07:30 PM
DoneDunIt
May 10, 2010 08:44 PM
bulletpruf
34
Apr 1, 2010 08:30 AM
billyb
Oil & Lubrication
38
Oct 30, 2001 08:02 PM
