Sponsored by: Real Truck
vin # help
Old Jul 27, 2003 | 07:44 PM
sharky's Avatar
sharky
Question vin # help
I just purchased my first super duty a 2002 f350 lariat. Is there a way to find out all of the options the truck came with by using the vin #. My wife has chebby suburban and had a local dealership run the vin on it they printed a list with every option the truck came with when new. When I stopped by my local ford dealer he looked at me like I was on drugs. Any help is appreciated.
Old Jul 27, 2003 | 07:54 PM
99f350sd's Avatar
99f350sd
vin # help
No but you can wait 10 years and get a build sheet. Thats what ford told me. Also sometimes there is a build sheet under the seat.
There are ways to recognize some of the options just ask and I'm sure you will get answers..
Good luck with your new SD
Old Jul 27, 2003 | 08:04 PM
johnsdiesel's Avatar
johnsdiesel
vin # help
VIN NUMBER:
The first three vehicle identification number (VIN) positions are the world manufacturer code.
1FD — Ford Motor Company, USA, incomplete vehicle
1FM — Ford Motor Company, USA, multi-purpose vehicle
1FT — Ford Motor Company, USA, truck, completed vehicle
2FM — Ford Motor Company, Canada, multi-purpose vehicle
3FD — Ford Motor Company, Mexico, incomplete vehicle
The fourth VIN position is the vehicle brake type and GVWR code (all vehicles use hydraulic brakes).
N — 8,501-9,000 pounds GVWR with driver and front passenger air bags
S — 9,001-10,000 pounds GVWR with driver and front passenger air bags
W — 10,001-14,000 pounds GVWR with driver and front passenger air bags
X — 14,001-16,000 pounds GVWR with driver and front passenger air bags
A — 16,001-19,500 pounds GVWR with driver and front passenger air bags
H — 8,501-9,000 pounds GVWR, without air bags (Mexico)
J — 9,000-10,000 pounds GVWR, without air bags (Mexico)
K — 10,001-14,000 pounds GVWR, without air bags (Mexico)
L — 14,001-16,000 pounds GVWR, without air bags (Mexico)
M — 16,001-19,500 pounds GVWR, without air bags (Mexico)
Positions 5 through 7 indicate vehicle line, series and body type.
F20 — F-250, Regular Cab, 4x2, single rear wheels
X20 — F-250, SuperCab, 4x2, single rear wheels
W20 — F-250, Crew Cab, 4x2, single rear wheels
F21 — F-250, Regular Cab, 4x4, single rear wheels
X21 — F-250, SuperCab, 4x4, single rear wheels
W21 — F-250, Crew Cab, 4x4, single rear wheels
F30 — F-350, Regular Cab, 4x2, single rear wheels
X30 — F-350, SuperCab, 4x2, single rear wheels
W30 — F-350, Crew Cab, 4x2, single rear wheels
F31 — F-350, Regular Cab, 4x4, single rear wheels
X31 — F-350, SuperCab, 4x4, single rear wheels
W31 — F-350, Crew Cab, 4x4, single rear wheels
F32 — F-350, Regular Cab, 4x2, dual rear wheels
X32 — F-350, SuperCab, 4x2, dual rear wheels
W32 — F-350, Crew Cab, 4x2, dual rear wheels
F33 — F-350, Regular Cab, 4x4, dual rear wheels
X33 — F-350, SuperCab, 4x4, dual rear wheels
W33 — F-350, Crew Cab, 4x4, dual rear wheels
F34 — F-350, Regular Cab (Chassis Cab), 4x2, single rear wheels
X34 — F-350, SuperCab (Chassis Cab), 4x2, single rear wheels
W34 — F-350, Crew Cab (Chassis Cab), 4x2, single rear wheels
F35 — F-350, Regular Cab (Chassis Cab), 4x4, single rear wheels
X35 — F-350, SuperCab (Chassis Cab), 4x4, single rear wheels
W35 — F-350, Crew Cab (Chassis Cab), 4x4, single rear wheels
F36 — F-350, Regular Cab (Chassis Cab), 4x2, dual rear wheels
X36 — F-350, SuperCab (Chassis Cab), 4x2, dual rear wheels
W36 — F-350, Crew Cab (Chassis Cab), 4x2, dual rear wheels
F37 — F-350, Regular Cab (Chassis Cab), 4x4, dual rear wheels
X37 — F-350, SuperCab (Chassis Cab), 4x4, dual rear wheels
W37 — F-350, Crew Cab (Chassis Cab), 4x4, dual rear wheels
F46 — F-450, Regular Cab (Chassis Cab), 4x2
W46 — F-450, Crew Cab (Chassis Cab), 4x2
W42 — F-450, Crew Cab (with box), 4x2, dual rear wheels
W43 — F-450, Crew Cab (with box), 4x4, dual rear wheels
F47 — F-450, Regular Cab (Chassis Cab), 4x4
W47 — F-450, Crew Cab (Chassis Cab), 4x4
F56 — F-550, Regular Cab (Chassis Cab), 4x2
W56 — F-550, Crew Cab (Chassis Cab), 4x2
F57 — F-550, Regular Cab (Chassis Cab), 4x4
X46 — F-450, SuperCab (Chassis Cab), 4x2
X47 — F-450, SuperCab (Chassis Cab), 4x4
X56 — F-550, SuperCab (Chassis Cab), 4x2
X57 — F-550, SuperCab (Chassis Cab), 4x4
W57 — F-550, Crew Cab, (Chassis Cab), 4x4
U40 — Excursion, 4x2, XLT
U41 — Excursion, four-door, 4x4, XLT
U42 — Excursion, four-door, 4x2, Limited
U43 — Excursion, four-door, 4x4, Limited
The eighth VIN position is the engine displacement and number of cylinders.
L — 5.4L, Modular, SOHC, EFI, V8, Gas
S — 6.8L, SOHC, EFI, V10, Gas
F — 7.3L, OHV, DI Turbo, V8, Diesel
Z — 6.8L, gaseous fuel prep (F-Series)
D — 6.8L, propane only (F-Series)
B — 5.4L, propane only (F-Series)
The ninth VIN position is a government assigned, computer-generated check digit.
The tenth VIN position is the model year code.
· 2 — 2002
The eleventh VIN position is the assembly plant code.
S — Allen Park (Allen Park, Michigan)
E — Kentucky Truck (Jefferson County, Kentucky)
M — Cuautitlan (Cuautitlan, Mexico)
The last six VIN positions are an alphanumeric code for the vehicle build sequence. This is also the vehicle serial and warranty number.
· A0000-E99999 — Ford Division
Old Jul 27, 2003 | 08:06 PM
johnsdiesel
vin # help
VEHICLE CERTIFICATION LABEL:
Exterior paint codes may be listed as a two-part code. The first set of characters listed indicate the vehicle primary body color code. The second set of characters listed (if applicable) indicated a two-tone or accent body color code.
AQ — Arizona Beige (clear coat), F-Series
BY — School Bus Yellow, Mexico sold only, F-Series
CX — Dark Shadow Gray (clear coat), F-Series
F1 — Vermilion Red (clear coat), F-Series
EP — Vermilion Red Solid, Mexico sold only, F-Series
FN — Dark Toreador Red, F-Series
GX — Dark Toreador Red, Mexico sold only, F-Series
L2 — True Blue (clear coat)
LR — Sapphire Blue (clear coat), F-Series
PB — Jewel Green, Mexico sold only, F-Series
PK — Chesapeake Blue, Mexico sold only, F-Series
PY — Highland Green (waterborne), F-Series
UD — Ebony, F-Series
TX — Bright Silver, Mexico sold only, F-Series
YO — Oxford White, Mexico sold only, F-Series
Z1 — Oxford White, Mexico build U.S. sold, F-Series
Z1 — Oxford White (clear coat), F-Series
Z3 — Silver Metallic (clear coat), F-Series
FL — Toreador Red, Excursion
JP — Silver Birch Metallic, Excursion
LD — Medium Wedgewood Blue, Excursion
P5 — Aspen Green, Excursion
ST — Estate Green, Excursion
TK — Mineral Gray, Excursion
UA — Ebony, Excursion
YZ — Oxford White, Excursion
Wheelbase
137 — 137-inch wheelbase (F-Series, Excursion)
141 — 141-inch wheelbase (F-Series)
142 — 142-inch wheelbase (F-Series)
156 — 156-inch wheelbase (F-Series)
158 — 158-inch wheelbase (F-Series)
162 — 162-inch wheelbase (F-Series)
165 — 165-inch wheelbase (F-Series)
172 — 172-inch wheelbase (F-Series)
176 — 176-inch wheelbase (F-Series)
189 — 189-inch wheelbase (F-Series)
200 — 200-inch wheelbase (F-Series)
201 — 201-inch wheelbase (F-Series)
Brake Type
B — Four-wheel anti-lock brakes system (ABS)
Interior trim codes are listed as a two-part code. The first character listed identifies the trim type. The second character listed identifies the interior trim color.
Interior Trim Type
K — Knitted vinyl bench seat, F-Series
C — Cloth bench seat, F-Series
F — Cloth captains chairs, Excursion
F — Flight bench seat, Mexico sold F-Series XLT only
G — High back cloth individual seats, F-Series
H — High back knitted vinyl individual seats, F-Series
J — High back vinyl individual seats, F-Series
3 — Cloth 40/20/40 seats, F-Series/Excursion
D — Cloth 40/20/40 seats with integrated restraints, F-Series
8 — Leather 40/20/40 seats, F-Series
9 — Leather 40/20/40 seats with integrated restraints, F-Series
2 — Cloth captains chairs, F-Series
6 — Cloth captains chairs with integrated restraints, F-Series
4 — Leather captains chairs, F-Series/Excursion
7 — Leather captains chairs with integrated restraints, F-Series
5 — Leather quad captains chairs, F-Series
L — Leather captains chairs, Excursion Limited
B —Leather captains chairs with vinyl rear bench, F-Series
M—Cloth 40/20/40 seats with rear bench mono. F-Series
P—Leather captains chairs with vinyl rear bench, F-Series
Interior Trim Color
H — Medium Parchment, F-Series
E — Medium Flint, F-Series/Excursion
B—Ebony, F-Series
D—Dark Flint, F-Series
Tape/Paint Stripe (TP/PS)
D — Light Argent/Medium Platinum/Light Argent, F-Series XLT
E — Arizona Beige/Dark Sandalwood/Arizona Beige, F-Series
F — Wild Strawberry/Dark Shadow Gray/Wild Strawberry, F-Series
Radio Type
7 — AM/FM stereo with clock, F-Series
G — Delete AM/FM stereo with clock, all other components installed, F-Series
9 — AM/FM stereo with cassette and clock, F-Series/Excursion
R — Delete AM/FM stereo with cassette and clock, all other components installed, F-Series
K — AM/FM stereo with cassette and compact disc player, F-Series/Excursion
Y — Delete standard AM radio with clock, F-Series
1 — AM/FM stereo with cassette and in-dash six disc compact disc (CD) changer, F-Series/Excursion
Axle Type
31 — 3.73 non-limited slip, F-250/Excursion
C1 — 3.73 limited slip, F-250/Excursion
32 — 4.10 non-limited slip, F-250
C2 — 4.10 limited slip, F-250/Excursion
33 — 4.30 non-limited slip, F-250
C3 — 4.30 limited slip, F-250/Excursion
36 — 4.56 non-limited slip, F-250
C6 — 4.56 limited slip, F-250
41 — 3.73 non-limited slip, F-350 (single rear wheels)
D1 — 3.73 limited slip, F-350 (single rear wheels)
42 — 4.10 non-limited slip, F-350 (single rear wheels)
D2 — 4.10 limited slip, F-350 (single rear wheels)
43 — 4.30 non-limited slip, F-350 (single rear wheels)
D3 — 4.30 limited slip, F-350 (single rear wheels)
46 — 4.56 non-limited slip, F-350 (single rear wheels)
D6 — 4.56 limited slip, F-350 (single rear wheels)
61 — 3.73 non-limited slip, F-350 (dual rear wheels)
F1 — 3.73 limited slip, F-350 (dual rear wheels)
62 — 4.10 non-limited slip, F-350 (dual rear wheels)
F2 — 4.10 limited slip, F-350 (dual rear wheels)
63 — 4.30 non-limited slip, F-350 (dual rear wheels)
66 — 4.56 non-limited slip, F-350 (dual rear wheels)
F6 — 4.56 limited slip, F-350 (dual rear wheels)
81 — 3.73 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E1 — 3.73 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
82 — 4.10 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E2 — 4.10 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
83 — 4.30 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E3 — 4.30 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
86 — 4.56 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
E6 — 4.56 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
88 — 4.88 non-limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
EW — 4.88 limited slip, F-350 Chassis Cab, narrow frame (dual rear wheels)
G3 — 4.30 limited slip, F-450 Chassis Cab
73 — 4.30 non-limited slip, F-450 Chassis Cab
78 — 4.88 non-limited slip, F-450 Chassis Cab
G8 — 4.88 limited slip, F-450 Chassis Cab
75 — 5.38 non-limited slip, F-450 Chassis Cab
G5 — 5.38 limited slip, F-450 Chassis Cab
GW — 4.10 limited slip, F-450 Chassis Cab
98 — 4.88 non-limited slip, F-550 Chassis Cab
K8 — 4.88 limited slip, F-550 Chassis Cab
95 — 5.38 non-limited slip, F-550 Chassis Cab
K5 — 5.38 limited slip, F-550 Chassis Cab
KW — 4.10 limited slip, F-550 Chassis Cab
Transmission Type
E — Four-speed automatic overdrive (4R100), gasoline engines, F-Series/Excursion
9 — Four-speed automatic overdrive (4R100), diesel engine, F-Series/Excursion
6 — Six-speed manual, Dana ZF (M6HD-6), F-Series
5 — Six-speed manual, F-Series (5.4L, 6.8L Gas)
2 — Five-speed manual, F-Series (5.4L, 6.8L Gas/LPG), Mexico only
Springs
Springs codes are listed as a two-part code. The first character listed is for the front springs. The second code listed is for the rear springs. Auxiliary rear springs may also be listed.
Front Springs — F-Series
Base part number — 5310 (RH/LH)
Pre-fix — F81A
B — Suffix BA
C — Suffix CA
D — Suffix DA
E — Suffix EA
F — Suffix FA
G — Suffix GA
H — Suffix HA
I — Suffix RA
J — Suffix SA
K — Suffix TA
L — Suffix UA
Pre-fix — 1C34
S — Suffix AAA
T — Suffix ABA
U — Suffix ACA
V — Suffix ADA
W — Suffix AEA
X — Suffix AFA
Front Springs — Excursion
Pre-fix — YC35
G — Suffix G
H — Suffix H
S — Suffix S
Pre-fix — 1C34
AG
AH
AJ
Rear Springs — F-Series
L — Rear air suspension
B — 1C34-5560-CB, F-250, F-350
C — 1C35-5560-DB, F-250, F-350
D — YC35-5560-EA, F-250, F-350
M — YC35-5A975-AA, F-450, F-550
N — YC35-5A975-BA, F-450, F-550
Auxiliary Springs — F-Series
A — YC35-5588-A (wide frame)
D — F81A-5588-D (narrow frame)
Rear Springs — Excursion
Base part number — 5560 (RH/LH)
Pre-fix — YC35
A — Suffix A
Pre-fix — 1C34
B — Suffix B
Old Jul 31, 2003 | 09:56 PM
aughtx's Avatar
aughtx
vin # help
Where is the Vehicle Certification Label located on the vehicle?
Old Jul 31, 2003 | 10:21 PM
99f350sd's Avatar
99f350sd
vin # help
open the drivers door below the latch on the truck not the door
Old Feb 25, 2021 | 03:06 PM
barrytx's Avatar
barrytx
ok I can't figure out why my VIN number doesn't follow the above legend. My vin off the door sticker is: 1FTNX20555EC46061. I can follow along until X20 then it goes wonky.
Old Feb 25, 2021 | 06:45 PM
Just Strokin's Avatar
Just Strokin
Ford ETIS report
Old Feb 25, 2021 | 07:09 PM
barrytx's Avatar
barrytx
Thanks @Just Stroken appreciate the help. Ton of info there - i have 265K miles on it and bought it six years ago for 3K. Solid truck just needs a new bed. Thanks again.
Old Feb 25, 2021 | 09:12 PM
Flattus's Avatar
Flattus
i emailed my dealer and they sent me a window sticker pdf. for my 2014 there was somethings on there that the vin decoder didn't tell me.
Old Feb 26, 2021 | 08:19 AM
farmerfromkansas's Avatar
farmerfromkansas
My engine code is Y on my vin, but there is no Y in the list. Down to that point everything is right with the list and truck.
Old Feb 26, 2021 | 04:17 PM
Just Strokin
See if this link will help. You may have to click on the year of your truck.
https://www.blueovaltrucks.com/tech-...v-i-n-decoder/
Old Feb 26, 2021 | 07:57 PM
farmerfromkansas
Now I have questions. The chart for light truck MPV has code Y for V-10, 305 hp, or the light medium or heavy truck chart has Y for a 6.0 diesel. My truck is a F-450, and has a V-10 gas engine. So is a F-450 a light, or medium truck over 11,000 lbs? The 4th digit says it is a 14,001-16,000 lb GVWR .
Old Feb 26, 2021 | 08:35 PM
Just Strokin
What does the VIN door label say your GVRW is? I suspect it is obvious you do not have the 6.0, so, you must have the V10
Old Feb 27, 2021 | 11:13 AM
farmerfromkansas
The door sticker says 16000 gvwr. Yes I have the V-10, the emblems say triton v10. Just wondering how they decide what engine to put in a truck, going by the vin. The other thing is, I would like to know if the truck has the original engine, but can't locate any engine ID numbers. Google says it is on the left rear, but have yet to locate it. The engine does not use oil, is pretty clean, and runs like a top, has 191,000 miles, and wondering what kind of maintenance it would need, if it really has original mileage. When you buy a used truck, you have no idea if the engine might have been replaced, especially if there have been multiple owners, which I suspect this truck has had.
