The electrical nightmare need help
Old May 1, 2015 | 10:23 PM
Jeffkniseley's Avatar
Jeffkniseley
So bought a 2001 excursion 7.3l deisel runs great after it starts has to be plugged in to start.
I am having an electrical problem with it.
When you turn the parking lights on the back lights are very dim and the 3rd bake light goes on.
With the lights off:
If you press the brake pedal the front turn signals light up.
If you put a turn signal on it stays lit. Sometimes it blinks sometimes it does not.
If I turn the hazards on they both blink and the tied brake light goes out?
What did I get my self into.
Old May 2, 2015 | 12:16 AM
Psyclopse's Avatar
Psyclopse
Just taking a wild guess, I'd probably look at the multi-function switch (turn signal switch) AND the grounds to the body. Maybe test the headlamp switch too.
Do you know any history of the vehicle? Flood recovery perhaps?
Old May 2, 2015 | 07:48 AM
Jeffkniseley
The truck was in Wisconsin its whole life from what I know. I will check the switch toDay
Old May 2, 2015 | 04:11 PM
Jeffkniseley
I can't figure it out:/
The lights are dim
With the lights off and you bread the brake the front signals come on???
If the blinker is on all the back lights blink even the 3rd brake light.
My lights are really dim I need the truck.
Old May 2, 2015 | 07:38 PM
J ballan's Avatar
J ballan
My guess would be a bad ground somewhere. That causes some funny things to happen sometimes. Check all your grounds especially body to frame.
Old May 2, 2015 | 08:39 PM
Jeffkniseley
I am not sure where the ground points are in this truck.
I did fix the problem by adding a ground wire to both tail lights everything is working perfect now.
Old May 5, 2015 | 11:03 PM
superdave02f552's Avatar
superdave02f552
Originally Posted by Jeffkniseley
I am not sure where the ground points are in this truck. I did fix the problem by adding a ground wire to both tail lights everything is working perfect now.
I have a ford manual I can tell you where the ground should be for that
Now if I can remember to look
danman223
Aug 9, 2018 01:31 PM
pittdog1977
Jun 3, 2014 09:53 AM
mario9272
Jul 8, 2013 11:03 AM
chambeab
Jul 2, 2012 10:50 AM
1997 f150 4.6l
1997 - 2003 F150
Mar 11, 2011 01:04 AM
