Start issue
Old May 20, 2015 | 11:58 AM
  #31
hydro man 17's Avatar
hydro man 17
Sound like you may have some EBPV / sensor issues. Check sensor and or cleaning the tube from the manifold to the EBPV may be in order.
Old May 20, 2015 | 03:48 PM
  #32
Jeffkniseley's Avatar
Jeffkniseley
I will probably clean that also.
Update:
Since it won't start today I ran home took the valve cover off and 2 injectors are not spitting oil.
So now what time to pull all injectors and send them in to get rebuilt or what else can I do.
Old May 20, 2015 | 08:08 PM
  #33
F350-6's Avatar
F350-6
If they start spitting oil after it warms up, then yes, it's time for new or rebuilt injectors.
You could also try some of the rev x or hot shot secret, but the results seem better suited for the 6.0 injectors and don't have much luck on the 7.3.
If you go with rebuilt injectors, go with one of the reputable dealers that are recommended here. Stay away from places like Pensacola diesel who have great prices, but a long history of poor results.
And most of the rebuild guys will sell you rebuilt injectors and let you return your old injectors as cores so you're not down the time of sending yours in and waiting.
Old May 20, 2015 | 08:22 PM
  #34
Jeffkniseley
so its pretty dead set on needing injectors then? possibly fix them myself?? how is rosewood? it was like 500 to have them rebuild well cleaned inside and out and flow tested. suggestions?? i need my family vehicle back soon here things are tight packing everyone in the car. i can't find any cheaper used one that are good either.
Old May 20, 2015 | 08:30 PM
  #35
F350-6's Avatar
F350-6
Jim at Rosewood is good. No problems with him.
I can't say you're dead set on needing injectors, but as you can tell from my posts, that's what it sounded like to me from the beginning.
I would recommend you starting the truck and letting it warm up to watch and see if the injectors not spitting oil start spitting oil and that coincides with the truck running better. That's a pretty reliable indicator of bad injectors.
You can also call Jim and get his input, or send him a PM on this forum since he participates here at FTE. Jim will have injectors on the shelf he can ship you and allow you to send yours in as cores after the swap.
Old May 20, 2015 | 08:36 PM
  #36
Jeffkniseley
I will give him a call tomarrow.
All the injectors where spitting oil while it was running. ( was 50degees out)
2 injectors on 1 side where not spitting oil not running just cranking (36 degrees)
Old May 26, 2015 | 06:45 PM
  #37
Jeffkniseley
Finally had some time today to work on the truck.
Got all 8 injectors out it was a fun hour and a half. Now I need to getting them sent to rosewood.
Old Jun 4, 2015 | 09:24 PM
  #38
Jeffkniseley
So got my injectors back today. Was excited left work early to install them. Got it all done and no start what now!
Old Jun 5, 2015 | 12:24 PM
  #39
Pikachu's Avatar
Pikachu
It's going to take a good bit of cranking before you build enough ICP for it to start. Got any way to monitor data?
Old Jun 5, 2015 | 02:30 PM
  #40
Jeffkniseley
So just keep cranking away ? I don't have a way to monitor it no.
Old Jun 5, 2015 | 04:35 PM
  #41
coax9952's Avatar
coax9952
Don't know if I'm poking the Bear or not but, Wasn't it running pretty good until you found all those bare wires? Are you sure you found them All? Your not gonna get any fire until youv'e fixed them all.....And there's 2 sides to inspect............and check inside both connectors. You may have just stirred up the nest...just sayin
Old Jun 5, 2015 | 04:41 PM
  #42
Jeffkniseley
It finally started instead of wearing a starter out I decided to fill the oil in the hpop. Air kept burping out and wala cranked for 5 seconds and Insta start.
Old Jun 5, 2015 | 09:51 PM
  #43
F350-6's Avatar
F350-6
It's gonna smoke for a while, and be slow to start several times until all the oil gets out of the exhaust system and all the air gets out of the oil rails.
Old Jun 5, 2015 | 10:19 PM
  #44
Jeffkniseley
Good to know it smoked like a chimney for the first 3 mins then went away for the most part
Salmon Guy
62
Oct 31, 2018 10:10 PM
86NWT
Oct 6, 2016 02:26 PM
Midnightss016
Dec 16, 2015 03:07 PM
90pioneer
Nov 5, 2011 09:09 PM
amoamo0311
19
Jan 17, 2009 02:17 AM
