Coolant Flush
Old Apr 30, 2015 | 12:27 PM
eutecticpt's Avatar
eutecticpt
Coolant Flush
I have read a good deal about flushing the coolant from a 7.3 Diesel and the procedure is pretty labor intensive. In the past, I have had good results using a flushing tee installed in the heater hose going from the heater core to the water pump and just following the instructions on the kit. Will this procedure work on a 1994 IDI Turbo? Will the entire cooling system be flushed using this technique?
Old Apr 30, 2015 | 01:31 PM
tjc transport's Avatar
tjc transport
i ain't rite
probably not.
i would flush the radiator, and then the block. once i get clear water out of both, i fill with coolant and sca's.
Old May 14, 2015 | 08:09 AM
eutecticpt's Avatar
eutecticpt
Only one reply? Anyone else want to chime in?
Old May 14, 2015 | 03:09 PM
madpogue's Avatar
madpogue
You won't get a complete flush while the thermostat is installed. So at the very least, you'll want to remove the thermostat and re-install the housing to do the flush. And even if you use the method on the flushing tee package, you'll still want to drain the remaining water out of both block drains and the radiator drain, to get the tap water out of the system. For the water constituent of the coolant, you want as little tap water and as much distilled water in the system as possible.
Unlike oil or fuel, the coolant is going to be in the system for several years. The flush procedure is something you don't want to skimp on.
Old May 16, 2015 | 08:14 AM
jayro88's Avatar
jayro88
I know a number of members have said they use the T's you are mentioning and like them. I have a van so it is difficult to get to the heater core hoses.
Many suggestions here are to remove the block drain plugs and install brass drain***** to allow easier/cleaner coolant changes. When I did mine (It was about a year ago). I used some of the Prestone coolant flush. I followed the directions on the bottle. Before the final fill I drained the system using the drain on the radiator and removed the drain plugs in the block. Then I refilled the system with the correct ratio of coolant/SCA/Distilled water.
I also replaced my thermostate while I was at it.
68bluebeast
Mar 8, 2015 08:48 PM
Harley320
Nov 17, 2007 09:57 AM
Smokin'
15
Dec 11, 2006 07:21 PM
Charger73400
1983 - 2012 Ranger & B-Series
Dec 20, 2004 11:18 AM
maa139
Nov 21, 2004 09:05 AM
