Antifreze
Old Nov 17, 2007 | 08:35 AM
Harley320's Avatar
Harley320
Question Antifreze
I have a 2000 EB Expy 115K I am looking to change my coolant any recomendations it has the original coolant and hoses quick lube place want to charge me 70.00 to do the job. I know I can do it myself and save money.
Old Nov 17, 2007 | 09:57 AM
holiday187's Avatar
holiday187
I use a bottle of water wetter a up of coolant and the rest distileed water. this is of course depending where you are. I"m in houston so it doesn't freeze here. If you'r where it freezes alot i would use 3 cups antifreeze a bottle of water wetter and the rest water. By the way like 2 days before you change you want drain all coolant and refill with radiator flush b prestone and the rest distilled water. after a day or two circulating through the system drain and it will have adequately flushed the system real good. and leave the heater on as much as you can those two days. That's what i do anyway.
