Guys I am restoring my late brothers 97 f250 XLT extended cab 4x4 5 sp. PSD. anyhow I cant find side mirrors with the upper bracket holes on underside of top need ideas TIA
Do you mean like this (but without the rust and dents)?
If that's what you're looking for, the actual Ford one's are by far the best (much less vibration and they stay put). But they're stinking expensive (about $120 for driver's and $180 for passenger if I remember correctly). Driver's part number is FOTZ-17696-B and passenger is FOTZ-17696-A.
If that's not what you're looking for then never mind
go to dealer with part number.
I just got a set two years ago, another set last year, and a set 2 motnhs ago all for different trucks
I got a set about a year ago. And Matt's right, you NEED to give them the part number. There are a ton of different mirrors and my dealer had no luck whatsoever figuring out which ones I needed, kept getting completely wrong ones or telling me they weren't available, until I got the P/Ns here. Then they ordered 'em and I had 'em in a few days.
Okay, I've ran into this problem as well. I've got a little different question though. I was looking to get black mirrors. The afmk units are all the wrong brackets (mounting holes above) at the top. I've seen some on ebay that are OEM black with the correct looking brackets, Can I assume these would fit? Are there just two styles/mounting configurations?
the part # for the ebay mirror is F1Tz-17682-D.<table width="100%" cellspacing="0" cellpadding="0"><tbody><tr><td class="attrLabels">also here's link to the pic http://dennis-carpenter.com/rear-vie.../F1TZ-17682-D/</td><td width="50%">
