Turn Engine by Hand?
Old Apr 29, 2015 | 04:52 PM
NCstRanger's Avatar
NCstRanger
Just replaced the head gaskets on a 1990 2.9L Ranger. I am ready to adjust the valve lash but when I try to turn my engine by hand, it started to go a little past TDC but now won't turn without popping back in place as soon as I let up pressure. I back out the adjuster screws on the rocker arms almost completely but not sure why this is happening. I did not take the fan off so I am only turning about 90 degrees from underneath the vehicle. Please help!
Old Apr 29, 2015 | 05:00 PM
NCstRanger's Avatar
NCstRanger
I can also add that one head was fine and was resurfaced while the other was cracked so I replaced it with a re-manufactured unit.
Old Apr 29, 2015 | 05:07 PM
NCstRanger's Avatar
NCstRanger
Figured it out, I'll leave this up for future reference in case anyone has the same issue... Truck was in gear... Put it back in neutral and can turn the crank with 1 finger!
Old Apr 29, 2015 | 05:52 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Nobody ever makes mistakes around here! (Haha)
dbgard57
Oct 16, 2017 10:27 AM
jfarcas
16
May 24, 2007 08:15 PM
manofcaldwell
Jan 17, 2007 04:46 PM
laka
Aug 10, 2002 10:19 PM
