4wd switch 93 EB 351w
Ok guys/gals I have a 93 full size Bronco. The 4wd doesn't work. I have replaced the control module located on the passenger side kick plate. Well that didn't fix it. So next step is the control switch. I found one on eBay but it is for a ranger/bronco/explorer. Looks just like mine but not sure if it's the same. Can some HELP ME!!
Are you absolutely certain that the shift motor is good or at the very least it hasn't gotten stuck between shift positions? If it has, the module doesn't "know" what position it is in and won't send electricity to it to make it shift. This means you will have to remove it, reposition it to the neutral position and then try getting it to shift. This is a fail-safe built into the electronic t-cases. If the shift motor gets stuck between shift positions it stops and will not move electronically again until it is reset. This protects the case from being engaged with the shift motor between detents.
Jack Peterson
12-27-2016 12:51 PM
Jimmeh
1983 - 2012 Ranger & B-Series
15
01-15-2010 04:34 PM
oldzinner
05-30-2006 07:25 PM
