Need help! headlights dont work
Old Apr 28, 2015 | 02:56 PM
93calypsohatch's Avatar
93calypsohatch
77 F250 was installing headlight relay harness from bronco graveyard yesterday and now i have no headlights. Eliminated the new harness and plugged a headlight into the factory plug and still doesnt work so not a problem with the harness. No power at the factory plug checked w a test light. Anything i should check first? Fuses looked good but will test them tonight. Running lights work fine. Also noticed my cluster doesn't light up now???
Old Apr 28, 2015 | 03:15 PM
bkaul's Avatar
bkaul
Do you have power to the headlight switch?
Old Apr 28, 2015 | 03:24 PM
93calypsohatch
Must be some power because the headlight switch turns on the running lights but unsure whether thats the same power that the headlights use
Old Apr 28, 2015 | 03:28 PM
DeepRoots's Avatar
DeepRoots
Just for fun, turn on/off your highbeams.
Old Apr 28, 2015 | 03:31 PM
bkaul's Avatar
bkaul
Good point. I caught the lack of dash lights but missed the running lights.
I'd check the voltage at the various wires in/out of the switch and see what you do and don't have there - the fact that you lost the dash lights too is suspicious. Makes me wonder if you somehow shorted something when installing the harness and damaged the switch when you tried to turn it on the first time.
Old Apr 28, 2015 | 03:50 PM
93calypsohatch
Just went out to the barn. Turned on headlight switch nothing but running lights. Stepped on the bright switch and they turned on! Now seem to be working fine on high and low. Think my high beam switch may be bad?
Old Apr 28, 2015 | 04:40 PM
HIO Silver's Avatar
HIO Silver
YES....... IIRC, voltage still goes through it with low beams.
Old May 24, 2015 | 08:53 AM
DeepRoots's Avatar
DeepRoots
Sorry I forgot about this thread for a month....
Yes, the dimmer switch (hi beam/lo beam switch) is dying.
Bout all the lights run through that switch, and well, simply put it is a good place to start seeing how its on the floor, and often the most abused due to moisture and dirt.
DO change it, even if it works now, at the most annoying time it'll die again.
I've had to drive home before at 3am with nothing but hi beams :P
Pro-Tip:
Do not buy the autozone switch, or any low quality switch, they do not last very long in many times. Buy an NOS switch or other high quality unit, they'll last a very very long time (Ebay or Dennis Carpenter is the best bet).
kdwellssr
Jan 3, 2021 09:52 AM
quincyj34
Nov 10, 2015 03:58 PM
dutchhman
Jun 11, 2010 04:52 PM
f250hiboy
Aug 27, 2008 07:15 AM
slipnotic
1983 - 2012 Ranger & B-Series
Jun 2, 2007 01:48 PM
