Headlights Flickering
Old Jun 1, 2007 | 10:37 PM
slipnotic's Avatar
slipnotic
As I was coming home tonight my headlights went in an out 3 times then come stayed back on until I got home. First thing I thought was oh no my alternator is going, but there was no lights on the instrument panal indicating this, or any interior lights dimming in or out. The only thing that was affected was the headlights, so could it maybe be something simple as a headlight switch?
Any help would be highly appreciated!
Btw its a 92 3.0 Custom
Old Jun 2, 2007 | 08:36 AM
sfcwoodret's Avatar
sfcwoodret
Check and make sure all the connections to the headlights are tight and that nothing has come loose from the wiring harness.
Old Jun 2, 2007 | 09:16 AM
pawpaw's Avatar
pawpaw
To go along with sfcwoodret's ideas, I'd also check the chassis ground connection from the battery cable to the radiator support & the headlight to chassis ground points.
Maybe the headlights power relay belongs on the suspect list too.
Let us know what you find.
Old Jun 2, 2007 | 01:48 PM
Exploder02's Avatar
Exploder02
Seen this problem before on a Ranger about that age... check your headlight switch, then Check the turnsignal cluster... On the one I was looking at it, it didn't have headlight relays, the power for the headlights runs through the turn signal cluster (for High Beams) and the turnsignal cluster was burned up (visible "cooking" evident)... got a replacement at a junkyard, fixed it right up.
AustinF250
Apr 30, 2013 10:20 PM
nikolass
May 22, 2010 11:58 PM
JCastellaw
1966 - 1977 Early Broncos
13
Dec 25, 2007 03:51 PM
kenpep2
Electrical Systems/Wiring
Sep 28, 2003 07:37 PM
Lruger
May 30, 2003 07:53 AM
