U-joint?
Old Apr 28, 2015 | 08:37 AM
Hunt1's Avatar
Hunt1
U-joint?
Hi all,
I have a 01 diesel 4x4. F250. At 40 to around 60mph I have vibration and again at around 30mph. At 65 and above no vibration. On acceceleration when going 40 to 60 there is like a clunk I can feel in the floorboard. When I stop and put it in reverse there is nothing but when put in drive ther is a clunk that sound like metal. Is this a u-joint or carrier? Thinks for your help!
Steve
Old Apr 28, 2015 | 10:00 AM
tjc transport's Avatar
tjc transport
i ain't rite
probably the rear universal.
Old Apr 28, 2015 | 12:31 PM
SkySkiJason's Avatar
SkySkiJason
Have someone put it in gear while you look at carrier and u-joints.
I recommend Spicer non-greaseable u-joints if that's what ya need. They have a MUCH better grease seal and tend to last longer since dirt can't get in them as easy.
Old Apr 28, 2015 | 04:42 PM
F250_'s Avatar
F250_
The clunk indicates that you need to lube up the splines on your slip yolk shaft. Not too much grease, though, or it will hydrolock and the shaft won't slip back and forth as it should. Think "very thin film".
Old Apr 28, 2015 | 05:26 PM
DieselDenny's Avatar
DieselDenny
New User,
I/we understand and are here to help.
Did you search the site for past posts regarding this issue.
If not, U can and there is a plethora of posts for you to dig into.
If so and you still can't resolve it, get right back in here.
Denny
BluePitt
Apr 4, 2012 07:54 AM
erichy
Dec 10, 2011 08:45 AM
bulkfever
1983 - 2012 Ranger & B-Series
20
Mar 26, 2008 06:09 PM
78bronco
Jan 1, 2003 05:41 PM
Shannonm1
Dec 19, 2002 07:41 PM
