I screwed up
Old Dec 10, 2011 | 07:59 AM
erichy's Avatar
erichy
I screwed up
I did the slip joint lube to get rid of the clunk and when I did it I had to hammer the driveshaft to get it out and put it back in. I marked the front of the shaft to put it back where it was but not the back. I now have a pretty bad vibration above 45 mph. Could I have damaged the carrier thing where the two shafts meet when I was hitting on the shaft to put it back on? The u joint seems to be ok. I'm going to rotate the rear 180 degrees to see if it helps today. Anybody ever had a driveshaft vibration problem?
Old Dec 10, 2011 | 08:45 AM
clux's Avatar
clux
It may be that the driveshaft is 180* out, but If you had to hammer the slip joint to get it back together it is probably binding up. You need to get that resolved as well.
erichy
Jan 25, 2012 05:23 PM
VTX1800C
Nov 12, 2008 03:12 PM
Dobbinicus
Mar 23, 2008 08:17 PM
m78
24
Mar 4, 2008 04:20 AM
cpettymore7777
Jan 2, 2004 10:01 PM
