ex vibration
Old Mar 27, 2012 | 01:27 PM
BluePitt's Avatar
BluePitt
ex vibration
I have a vibration coming from the rear. I put new tires on yesterday. Nitto terra grapplers 285*75*16.
Still it vibrates. I'm on the verge of doing a complete driveshaft overhaul very soon. The u_joints look a little worn but I can't feel any slop. I have watched a few videos on the slip yoke. How do you fix the slip yoke.
Old Mar 27, 2012 | 01:46 PM
BassFantasizer's Avatar
BassFantasizer
Great Timing on this thread!
A Ford mechanic friend and I are just starting to diagnose a drive train vibration in mine, too. The frequency suggests drive shaft or u-joint, but there's nothing obvious yet.
Old Mar 27, 2012 | 01:58 PM
TrdLtly's Avatar
TrdLtly
TreadLightly
I am with you guys. Same problem. Same symptoms.
Old Mar 28, 2012 | 08:20 AM
BassFantasizer
I won't get to check anything until this weekend, but the recommendation is that if none of the u-joints appear "at fault" (no slop, wear marks, grease, shiny metal, etc.) it's probably the front u-joint or the drive shaft bearing if the Ex is equipped with a split drive shaft.
Thought that I'd share that in case anyone was inclined to do some diagnostics in the next couple of days....
Old Apr 4, 2012 | 12:11 AM
wikdwest's Avatar
wikdwest
I also have a vibration and talked to my mechanic. He said it is most likely the rear u-Joint. I will start there since it is a cheap fix, worst case, i have a new U-Joint if that isn't the problem.
Old Apr 4, 2012 | 05:40 AM
radmacks's Avatar
radmacks
I had crazy bad vibrations and could not figure it out, checked u joints they looked fine checked everything it all looked fine and tight. Dropped the shaft to lube up the slip joint. put the shaft on a jack stand and gave it a wiggle. The rear ujoint was shot. Funny thing is when the shaft was connected their was no noticeable play in the joint. I think the slip joint takes up the slack but still will cause the vibrations. I recommend dropping the shaft and then checking.
Old Apr 4, 2012 | 07:54 AM
BassFantasizer
Hi radmacks,
I checked mine over last weekend and found no play, oil, or signs of wear on and of the u-joints. (And with a 1-piece driveshaft there is no carrier bearing to worry about.)
U-joints are cheap I'm going to take the same approach that you did -- replace the mains and see what happens....
mgage06
Mar 13, 2012 07:00 PM
erichy
Nov 5, 2011 07:18 PM
fairlaniac
1983 - 2012 Ranger & B-Series
Apr 1, 2008 06:43 AM
m78
24
Mar 4, 2008 04:20 AM
batesfarmer
Jan 16, 2007 06:19 AM
