What size manifold studs?
Old Nov 13, 2020 | 06:18 PM
arse_sidewards's Avatar
arse_sidewards
It's Amazon. Lord knows they started off as G5 or G8 or whatever then the seller revised the listing. Not like it matters since they co-mingle inventory by SKU so if some seller ships in junk grade 2 or whatever then you have a chance of getting that. If you're concerned about what you're getting you should probably buy elsewhere or be prepared to test what you get.
kolobcanyon's Avatar
kolobcanyon
Originally Posted by The Frenchtown Flyer
I think if you take care not to over tighten them they will be fine. That has been my experience. Regardless of what strength you use check them occasionally for tightness.
I was super careful about that. Made sure it was 32 ft lbs exactly on all of them except the ones that are impossible to get a torque wrench on.
Old Nov 13, 2020 | 11:41 PM
The Frenchtown Flyer's Avatar
I approximate the torque on an unreachable bolt by putting the wrench on a torqued bolt and "budge" it, then replicate the effort on the unreachable one.
Old Nov 14, 2020 | 12:09 PM
kolobcanyon
good idea!
Btw those amazon studs I posted are grade 8. Not sure why they're not more obvious on the ad.
Old Jan 30, 2021 | 11:11 AM
kolobcanyon
Hey, does anyone know the specifications for the bolts that hold the Inline 6 intake manifold and exhaust manifold together? There should be two of them I believe?
99f350sd
Aerostar
Mar 17, 2014 04:29 AM
Bossdrum
Sep 11, 2012 05:04 PM
69crewcab
Oct 29, 2006 07:34 AM
FilmGuy
Oct 21, 2005 04:26 PM
