Sponsored by: Real Truck
110V Outlet
Old Apr 27, 2015 | 06:07 AM
spud57's Avatar
spud57
110V Outlet
Anyone have experience trouble shooting the 110V outlet in the console? I bought the truck used a couple years ago ('11 F250) and never had any need for it until now.
The green light is flashing, which indicates a fault. Not sure where to start.
S
Old Apr 27, 2015 | 11:36 AM
droldsmorland's Avatar
droldsmorland
Start with the owners manual if you have not looked at it yet? If you find the prob please report back so we all know the fix. Did you look at its fuse? Are you sure there isnt 110 VAC present?
Old Apr 27, 2015 | 12:49 PM
BCM's Avatar
BCM
That 110 is only good for about 40 watts max. What are you plugging into it?
Old Apr 27, 2015 | 06:32 PM
spud57's Avatar
spud57
Yes, I read the manual where it states that when the light flashes it is a fault and does not work. And yes, I checked the fuses. How do I know it's not working? Really?
And it is good for 150W as marked on the outlet cover and manual.
Looking for anyone that has experience with trouble shooting them.
Old Apr 27, 2015 | 08:10 PM
Just Strokin's Avatar
Just Strokin
There is a voltage converter module located in the bottom of the console. Not sure what the procedure to test it is. The part number is BC3Z-19G317-A. list for 255 at ford but one of the ford parts depts shows it for like 135 plus shipping. Used on on ebay, about 100.
Also the same module is located in the dash on the right side of glove box area for the dash 110v outlet.
Old Apr 28, 2015 | 05:21 AM
redford's Avatar
redford
FTE Leadership Emeritus
Not much to troubleshoot. 12 volts DC in, 120 volts AC out. Unless your a very knowledgeable electronic technician there is nothing on the module for Joe Average to repair.
Also, be careful. 120 volts AC will give you a good jolt.
Old Apr 29, 2015 | 10:15 AM
droldsmorland
You wont have 110VDC at the outlet
Old May 3, 2015 | 12:15 PM
spud57's Avatar
spud57
Sorry guys but I ignored the "how do you know it doesn't work" question. I am not an idiot.
My question was trouble shooting it not whether it works. Thought someone may have some insight before I started looking.
I cycled the ignition a couple times and it is now working.
cpickner
Sep 21, 2011 11:42 AM
kevinheap
Oct 17, 2008 12:25 PM
bocephus_3349
Sep 4, 2007 06:35 PM
lonsdalecowboy
Dec 10, 2005 07:36 AM
celjel
1983 - 2012 Ranger & B-Series
Sep 30, 2004 06:38 AM
