New Problem.
Old Apr 30, 2015 | 01:54 PM
  #31
Rusty Axlerod's Avatar
Rusty Axlerod
Well shoot. I was hoping it would be an easy problem. 7 separate issues at the same time is pretty unlikely but not impossible.
Old Apr 30, 2015 | 03:25 PM
  #32
Yahiko's Avatar
Yahiko
How long did you watch it? I would take the SGII out of the cab and start wiggling
the harness and see if you get a drop in the Vref.
BTW if you call it anything but Vref most won't have a clue what your talking about.
Sean
Old Apr 30, 2015 | 06:59 PM
  #33
Thor'sHammer's Avatar
Thor'sHammer
The dealer I bought it from said that they reset codes and many have not returned after 200 miles of driving. They are giving me an egr valve, fan clutch and an injector to replace the faulty ones. I simply cannot believe it. A dealership GIVING parts to a customer for a vehicle that they sold.
Old Apr 30, 2015 | 08:44 PM
  #34
Yahiko's Avatar
Yahiko
Hmm, Is about all I can say at this point.
Sean
Old May 4, 2015 | 12:21 AM
  #35
Thor'sHammer
I'm starting the repair process in the morning tomorrow. I've got several parts from the dealer (surprisingly at no cost to me) and have to get a couple more things. I have the following;
Oil cooler kit
EGR valve
Fan Clutch assembly
1 remanufactured fuel injector to replace a failing #4 injector
Turbo rebuild kit
I'll check back in when everything is done.
Old May 5, 2015 | 06:20 PM
  #36
Thor'sHammer
I've found the following so far;
Stuck turbo vanes. It appears that the unison ring has never worked. The slot is worn in only one place and there was a burr on the ring causing it to bind. I've blended the burr and got the ring functioning properly.
Turbo shaft bearings worn. It has radial play but has not contacted the housing yet.
EGR valve stuck/not functional.
Fan clutch slip ring has no continuity.
Oil cooler nearly completely clogged. I put water in one side, nothing comes out the other.
Turbo drain tube o-rings leaking.
Accessory drive belt torn in multiple places.
On a lighter note, #4 injector may be good after all.
Old May 5, 2015 | 10:10 PM
  #37
Benchwrench's Avatar
Benchwrench
I take it that dealers don't fix a thing until after they sell. Evidently they just clear codes.
P.S. wasn't implying manually moving vane actuator on a running engine.
Old May 5, 2015 | 10:24 PM
  #38
78fordman's Avatar
78fordman
New Problem.
that's more than most used car places would do. buy a new unison ring while it's apart.
Old May 5, 2015 | 11:49 PM
  #39
Thor'sHammer
I have ordered another. Sad thing about all of this is that I bought this truck from a Ford dealership.
Old May 7, 2015 | 12:25 AM
  #40
Thor'sHammer
Installed the new oil cooler today. The unit I removed was some chinese made joint that was completely clogged. Should I have filled the pocket the oil cooler fits into with oil prior to installing it? The ford manual was unclear about that.
Tomorrow will be the installation of the intake manifold and removal of the heavily corroded battery cable. After that, I'm waiting on parts to rebuild the turbo and install the fan clutch.
Old May 7, 2015 | 02:14 AM
  #41
Yahiko's Avatar
Yahiko
If you remove the plastic stand pipe in the filter housing
and pour the oil down the center that should fill the right
places with oil.
Sean
Old May 11, 2015 | 07:00 AM
  #42
Thor'sHammer
I've got a new problem now.
My ECT will get up to 208-211 under heavy acceleration or traveling up a steep hill. It does come back down, but it varies on what it comes down to. I've seen 188, 190, 195..... Oh yeah, and my deltas are worse than before. I flushed the system through my with vc-9 and distilled water before the replacement and used fleet charge coolant afterwards. I see anywhere from 7 to 20 degree differences. I'm going to cold soak and look at the temp sensors later.
Old May 11, 2015 | 10:13 AM
  #43
Benchwrench
If you found the oil cooler plugged, it's best to find out what caused the foul and if the cause was addressed/ repaired.
Other than that, your temps seem normal under the conditions noted.
Old May 11, 2015 | 12:04 PM
  #44
Thor'sHammer
It was clogged with coolant gel and casting silt.
Old May 11, 2015 | 12:09 PM
  #45
Benchwrench
You're going to want to install a bypass coolant filter if you don't already have one.
