351 engine sudden knocking
Old Mar 15, 2002 | 01:56 PM
razer70's Avatar
razer70
Razer70....Hey guys,My 88 ford econoline was running just fine on my way home it a\started making a knocking or a lifter ticking noise on the passengers side of engine. Engine would not idle like it was and bogging a little.Sound likes it's coming from the valve cover but I haven't pinpointed exactly yet.Oil was just changed 1,000 miles ago synthetic 10-30 .I'ts fuel injected looks like a fun job just to take off the fuel injection intake just to get to the valve cover.Any tips on how I should go about it would be helpful. and are these 351 windsor engines notorious for any type of failure in this area.Thks razer...
Old Mar 15, 2002 | 04:34 PM
Lightning2Fast's Avatar
Lightning2Fast
sounds like a camshaft going south. kinda common for the 80's trucks. do a compression test. its a good start. could also pull a valve cover and crank the engine. this way you could see how much the valves are opening. also do an oil pressure test. maybe the pump is worn and the lifters are not pumping up. many possibilities here.
Old Mar 15, 2002 | 04:39 PM
Lightning2Fast
EXSIGS
28
Aug 16, 2012 09:56 AM
miottimouse
65
Jul 25, 2010 04:28 PM
razer70
Mar 22, 2002 08:57 PM
razer70
Mar 18, 2002 04:58 AM
razer70
Jan 30, 2002 03:30 PM
