89 ranger running really rough...
Old Mar 14, 2002 | 06:38 PM
buzzedhead's Avatar
buzzedhead
Post 89 ranger running really rough...
89 Ranger auto trans 2.9 EFI
truck jerks on the freeway under a load-kind of hesitates
I checked out intermitten and reads okay!! Runs really bad in overdrive on freeway.
Help!! I can't figure it out!!
Old Mar 14, 2002 | 06:51 PM
Phillip Guidry's Avatar
Phillip Guidry
sounds like a fuel pressure problem...change the fuel filter first.....if not the problem...check fuel pressure both cranking and running. When were the last set of plugs put in or a major tune up done ?
Phil
Old Mar 15, 2002 | 04:39 PM
Lightning2Fast's Avatar
Lightning2Fast
sounds like an arcing plug wire. spray the plug wires with water and see if you can get the engine to skip. if it skips after you spray then most likely the wires are shot. let us know what you find.
Old Mar 15, 2002 | 07:35 PM
webpilot's Avatar
webpilot
wolfe1104
3.0L V6
Jul 12, 2008 03:46 PM
Ranger123
Nov 9, 2007 02:57 AM
fordmanfox
1983 - 2012 Ranger & B-Series
Apr 8, 2007 02:11 PM
koalamazed
Mar 8, 2004 08:21 AM
CrazyFazy
Bronco II
Feb 24, 2004 09:58 AM
