6.2L V8 Discuss the 6.2L V8
oil leak
Old Apr 24, 2015 | 10:58 PM
Flatbed Ed's Avatar
Flatbed Ed
oil leak
Rear end slinging fluid and was 1 qt low. Time for a new seal.
Topped it off and will fix soon. 225,000 miles.
Old Apr 25, 2015 | 07:56 AM
rvpuller's Avatar
rvpuller
Veteran: Coast Guard
oil leak
With that many miles have you serviced the transmission, I'm thinking of draining the pan every 30K and just topping off the fluid with a filter change every other time.
I hate putting in pinion seals, the last time I had one go out on my work truck I had someone else replace it.
Denny
Old Apr 25, 2015 | 09:00 AM
Flatbed Ed's Avatar
Flatbed Ed
Denny
Yeah service the transmission around a hundred thousand miles or so time to do it again the last time I did it it was pristine clean this should cost about 30 bucks from ford. it I'll get it taken care of pretty soon
Old Apr 25, 2015 | 11:02 AM
clintbonnie's Avatar
clintbonnie
FYI.. I had a pinion seal go bad on my 99 superduty a while back.. It was caused by the breather hose being plugged up with a small insect nest at the end.. and building up pressure within the rear end.. it also damaged a wheel bearing seal..
Old Apr 25, 2015 | 06:44 PM
rvpuller's Avatar
rvpuller
oil leak
Had the same problem on my 2000 DRW but after I changed the way the frame clip was installed on the hose the leak stopped. When we got our 2013 I checked and the clip was the same way, pinching off the hose so I changed it.
Denny
Old Apr 25, 2015 | 09:12 PM
clintbonnie
Denny
Good to know.. I will check my new 2015 .. thx
Old Apr 26, 2015 | 08:47 AM
rvpuller's Avatar
rvpuller
oil leak
It takes a few years but in time it pinches it down
Denny
Old Apr 30, 2015 | 05:46 PM
Flatbed Ed's Avatar
Flatbed Ed
Had it fixed. Breather hose fine, just a worn, leaky pinion seal. $50 repair plus the part.
jwchenault
1997 - 2003 F150
May 30, 2015 11:15 PM
radmacks
Apr 15, 2011 07:39 AM
dsmisfits
Mar 9, 2011 03:49 PM
Jefe
Jun 8, 2006 11:45 AM
mino54
Jan 27, 2005 01:46 PM
