TR Sensor
Old Apr 23, 2015 | 10:17 PM
Drewbert's Avatar
Drewbert
Question TR Sensor
I have a 2013 ford f150 3.5L eco with 6r80 tranny in it. It came in on the hook dead with no start. Tested battery 12.6v, pulled starter, bench tested, came back bad. Replaced starter. Still no start. hooked up to obdII came back with P0705, P0706, P0707 and P1705. those are all TR Sensor Codes.
so I ran all the pinpoint tests and came to c6, where I was told to drain pan and inspect TR Sensor. It said if it was still connected to the Valve body replace the TR Sensor. I replaced the lead frame, as this is what appears to be indicated in the workshop manual. After I replaced the Lead Frame, I ran dtc's again and now only have P0706 and P0707. Any thoughts?
W7PSK
6.7L Power Stroke Diesel
Jan 28, 2016 11:41 AM
JOHN2001
Aug 9, 2012 09:21 PM
jellybean66
Mar 1, 2009 01:23 PM
2002f350crew
Aug 29, 2007 02:50 PM
TommyH
Jul 31, 2004 09:58 AM
