Cab Removal W/O Lift (Head Gaskets)
So instead of spending a few hours trying to find a way to hang about 1000# of steel above your head so you can play in the crush zone until your untimely demise...
Build or buy the head lifting bracket, and do it with the cab on.
https://www.ford-trucks.com/forums/1...l#post12575219
Seriously, you dimple the cab in one place, and remove half the HVAC box cover, and you can do heads with the cab on. If you want to get crazy about not having to kneel anywhere, remove the fan and cooler stack and stand in front of the engine.
https://www.ford-trucks.com/forums/1...b-on-hint.html
I firmly believe in cribbing almost anything with wood, because to work on tractors you pretty much have to use it at some point. But God almighty it's a job that can be done without any of the hassle of lifting the cab, so why buy trouble instead of doing on the ground like so many other people. Cheezit is a former tech who IIRC didn't even have a lift in his bay, he made a living doing these with the cabs on.
Having seen things from around the world, especially Southeast Asia, that's not too bad. It's based on a concrete slab, rather then soil, and he's got a windbreak in one direction. I'd rather see wider cribbing.
Also, growing up on a farm you learn to get creative. On a farm once you got her up off the frame with jacks so some 6x6 or 4x6 could go under, then two tractors with loaders would get're up to clear the motor .
I've seen a one year old Corvette in a dealership on a two post lift that had one pair of arms slide away that wasn't pretty, so I wouldn't be too quick to throw stones about the backyard. But if I had to do heads without a lift I'd just be doing it under the hood.
The following users liked this post:
on
Had 2 flats and no racks. Never saw a need. Flat backing all of it.... I have a comfy creeper.
It took that guy longer to prop that cab up then it would for me to pull the engine.
Theres no way I would be anywhere near that lifted cab either.
Heads with cab on is a 12 to 14 hour job. I just pulled the whole evap case and didnt split it.
Heads with cab off and a lift about 1 to 2 hours faster. After you have pulled a few cabs.
Engine r/r and heads not much more then in cab but imo the easiest way.
The service writer on the commercial side has told us the only way to pull heads or the engine is to lift the cab.... If I haven't done any wrenching myself I would believe what the "professional" tell me. Unknowingly by the vehicle owner this is just likely the preferred method of the mechanic at that dealership.
Having pulled a 6.0 myself, I would personally spend the extra hour pulling the front end out (grill, bumper etc) to pull the heads out. Being able to stand on that cross member is really nice compared to bruising your guts and colon laying across the motor...
So if I understand you correctly, you are saying there has never been a 99-2007 F250+ cab lifted at any Ford dealership?
