Harbor Freight has good and bad items. I've been using their $59.00 motorcycle lift on my Harley for 5 years now and it's been flawless. Their Pitman arm pullers last long enough for one shot and the casting snaps. Their large impact sockets have been flawless. It's called buyer be aware and educated. Point of interest. If you ever get a tile cutoff saw from them the saws have a bast*** size arbor and the only place that sells the replacement blades is HF.
One thing to note when removing injectors.
Plug the oil return holes and place some lint free towels
around and over things. Also small rubber hose cut to size and
placed in the returns will do the job. Then before you remove it
look to see all the parts are accounted for.
