OBD 1 scanner question
Old Apr 22, 2015 | 07:11 PM
jmuma2011's Avatar
jmuma2011
so I bought a OBD 1 scanner the other day for my 1997 F350 7.5L and when I went to do the key on engine on test. its suppose to tell you how many cylinders its testing right. Well it said it was only testing 6 cylinders and not 8. any ideas on why that is? I redid the test a few times and it says the same thing every time. I bought the INNOVA 3145 Ford Digital Code Reader if that helps at all. Thanks
Old Apr 23, 2015 | 06:43 AM
projectSHO89's Avatar
projectSHO89
Run the KOER self test using the common paperclip/CEL method and see what Cylinder ID the PCM is sending out and see if it matches what the Innova is displaying.
Old Apr 24, 2015 | 09:18 AM
Conanski's Avatar
Conanski
Dynamic engine tests like cylinder balance only work with MAF vehicles because MAP based systems do not have control over individual injectors.. they are fired in batches. You will find notes for this at various locations in the documentation for the Equus code reader.
Tater7633
Apr 16, 2015 06:03 PM
mike L
General Automotive Discussion
Jan 22, 2013 10:47 AM
foxracing0934
Oct 22, 2008 01:11 AM
kennedyford
Jul 7, 2006 01:53 PM
PWR
1983 - 2012 Ranger & B-Series
Feb 21, 2006 03:39 PM
