Rough Start 92 5.0
Old Apr 22, 2015 | 12:07 PM
Luigi711's Avatar
Luigi711
Rough Start 92 5.0
Hey guys,
This truck has got me stumped. I've looked around the internet to try to find a solution, but it seems my truck is doing things backwards.
It started out if it rained it would do it, now its pretty much every time it sits for 4 or more hours.
It'll start right up, but after a minute the engine light comes on, and it runs really rough then dies. When I go to restart it the fuel pump makes a humming noise (like it normally does) but this time it doesn't stop. I've tried both tanks and it does it on both. if i leave the key in on, it will go away after a minute or two. then it'll start right up. after about ten minutes of running I have no more problems. The other day, it was about five minutes after I started it. I did it to me at a light. So I tried to power through the light to pull off, It seemed like it was stuck in fourth gear. The engine light was on. I pulled off, turned it off, then back on, and it was back to normal. I've tried pulling the codes, but I seem to not get any. I'm not sure if I'm doing something wrong, or it's because they don't save. I'm thinking maybe the computer is going bad in it or I have wiring issues at this point.
Any help would greatly be appreciated.
92 F150 5.0 auto 2 wheel Dual tanks
Old Apr 22, 2015 | 06:49 PM
rla2005's Avatar
rla2005
Originally Posted by Luigi711
Symtpom 1: When I go to restart it the fuel pump makes a humming noise (like it normally does) but this time it doesn't stop.
Symptom 2: I've tried pulling the codes, but I seem to not get any. I'm not sure if I'm doing something wrong, or it's because they don't save.
Correct Diagnosis: I'm thinking maybe the computer is going bad.
You have a bad computer (PCM).
Remove the PCM from the truck. It comes out from the engine side of the firewall. Open it up then inspect it for signs of leaking capacitors like thisL
Old Apr 22, 2015 | 07:02 PM
Luigi711's Avatar
Luigi711
Thank You. I will look tomorrow. Would you recommend getting a new one or would one from the junkyard be ok?
Old Apr 22, 2015 | 07:05 PM
rla2005's Avatar
rla2005
There are no new ones......
Standard Motor Products sells trust worthy re-manufactured models. Napa and Rock Auto usually carry that brand.
You can also send yours in to be rebuilt here: ECU REPAIR NOW
If you go the junkyard route make sure to open it to inspect for the same problem. Very common these days!
Old Apr 22, 2015 | 08:13 PM
Luigi711's Avatar
Luigi711
Decided to pull it out before it got dark.
This is what I found.
Old Apr 22, 2015 | 09:13 PM
timbersteel's Avatar
timbersteel
Double capacitor failure.
If you have a TV/electronic repair shop, they may be able to salvage it before major damage occurs. Usually when they dump the electrolyte fluid, it will eat through the protective clear coating and then damage the traces.
Old Apr 23, 2015 | 09:04 AM
aj88V's Avatar
aj88V
I'd start by pulling the OBDS codes. They may not work if the computer is bad, but even that would tell you something.
Also suggest checking the EGR system.
Old Apr 24, 2015 | 07:46 PM
Luigi711's Avatar
Luigi711
Took half the day to track one down. Got it in and so far so good.
Thanks For All yer help!
1993FordF1505.0
Aug 29, 2015 10:56 PM
1993FordF1505.0
Aug 10, 2015 07:22 PM
Daveyj
Sep 9, 2014 03:24 PM
subford
Sep 3, 2012 07:50 PM
joe sto
Apr 7, 2008 07:56 PM
