I was following along on the r&r thread in the tech folder and I found this in the location of the resistor. Am I in the wrong location or do I have something different?
On my 05 Ex I had to change the part you are pointing at.
My problem was that the AC fan would work but only on high. I replaced the part four years ago and I haven't had a problem since.
One other issue is that there are two different resistors. The cheaper one is for trucks with the manual AC controls. Since I have the Eddie Bauer it has the digital ac controller and needs the more expensive resistor/controller. From what I remember you also have the more expensive resistor/controller. I think it was about $55 from Ford. The part number should be 19E624-AA, so you might find it cheaper on the Internet.
