Sponsored by: Real Truck
AC Blower Issues
Old May 27, 2015 | 09:47 AM
elilco's Avatar
elilco
Arrow AC Blower Issues
Hi Guys,
i wonder if any one out here can give me an advise.
i have 06 F350 6.0 my ac blower will not stop running even if the
AC control is off. did anyone has this happen to them? any advice would be
appropriated.
Thanks.....
Old May 27, 2015 | 11:15 AM
droldsmorland's Avatar
droldsmorland
Could be a bad blower resistor PCB(board) that shorted verses the more common open. <$30 part. Check its connector too.
Old May 27, 2015 | 09:14 PM
projectSHO89's Avatar
projectSHO89
Impossible, it cannot work that way.
Is this a manual or an automatic climate control system? If auto, it's probably a faulty blower speed control module.
Old May 27, 2015 | 09:23 PM
elilco's Avatar
elilco
Hi there. Mine is Automatic.
Old May 29, 2015 | 09:40 AM
droldsmorland
I've seen the connectors melt to where there is full 12vdc applied through the ground with fuse intact...motor ran regardless of fan selector or directional selector switch positions....not necessarily in a Ford, but yes possible.
To the OP that tid bit of info is useful. The climate control system is much different from the manual system. Im not up on Fords climate controls only the manuals. You need a schematic and the ability to interrupt one then dig into the dash. Generally not a DIYer thing if you dont have a print and a decent VOM.
We'll rely on projects recommendation to look at the speed control mod first. If that doesnt do it as I said I dont have a print so this is as far as I can go for you on line. You will need the pin outs to probe the module for outputs or you could just take a chance and replace it. Not sure on the cost. Post back either way to close the loop.
Old Jun 4, 2015 | 08:02 AM
elilco's Avatar
elilco
Hey guys Thanks for all your help i was able to fix it and it turned out to be Fan PCB. mine is located under the hood on the left side right by the blower motor. it was a bitch to get the second screw out i had to bend one of my tools to get it out. in the images you can see the PCB and the part i replaced. you will need to either know how to soldier or take it to a shop and have them do it for you. i did it and it took me all about an hour to do. the part was $17 plus shipping. a new PCB cost $170 and thats not the OEM.
Good Luck to everyone and thank you.
Old Jun 4, 2015 | 03:39 PM
droldsmorland
Thanks for closing the loop and the pics!
Old Mar 19, 2016 | 05:19 PM
AZwhite350's Avatar
AZwhite350
Resurrecting an old thread. I want to pull the blower motor controller (yes, I have EATC) but have not figured out how to move the ac accumulator so I can get to the lower screw. Any advice?
Philip Ringer
2015 - 2020 F150
Aug 15, 2019 04:02 PM
Bdomangue
Jul 14, 2019 12:39 PM
DarkStarMedia
Jun 1, 2017 06:59 PM
fmentlick
Jun 5, 2011 11:24 AM
