Dads old 47 ford
Old Apr 21, 2015 | 11:06 AM
Lwhitman's Avatar
Lwhitman
Dads old 47 ford
I just pulled my dads old 47truck out of the field and the steering is locked any one know how to in lock it the key is snaped off in side
Old Apr 21, 2015 | 12:33 PM
Tedster9's Avatar
Tedster9
Welcome to FTE
Old Apr 24, 2015 | 07:27 AM
f5fordgirl's Avatar
f5fordgirl
If the key is broken off, use a good flat blade screwdriver and some penetrating spray, and you should be able to turn it.
Old Jul 1, 2015 | 06:21 AM
billb2000's Avatar
billb2000
on the backside there is a spot that you can drill out a plug ,then the key and the part that holds the key will come out ,then I took it down and had a key made ,put it back up in there ,then the drill bit that I used to drill it out ,cut the end off of the bit about a half inch and glue that small back where you did the drilling!!
pthfndr80
Aug 16, 2016 08:39 PM
metriccar
Nov 20, 2013 07:44 AM
babgrip
Mar 31, 2008 12:20 PM
jcascio
15
Mar 26, 2007 06:19 AM
patrick_q
Feb 18, 2004 07:52 PM
