questions.
Old Apr 27, 2015 | 08:06 AM
greentruck72's Avatar
greentruck72
okay with those interesting ideas... would a bed with the fuel door work on my truck even though i have the fuel cap- round hole vs the fuel door.
and btw i actually had a better bed that i bought, but it had 2 fuel doors and didn't feel like welding the first one shut. what does a good quality MIG run?
Old Apr 27, 2015 | 08:21 AM
bkaul's Avatar
bkaul
If you swap to the other fuel filler style (door vs cap), you'll also need to swap filler tubes; it can be done though. My '74 has a fuel door on it (from the PO).
Old Apr 27, 2015 | 08:22 AM
greentruck72
okay quick question as well, could i put a C-II power steering on my 390 with the old style pump currently on it.
Old Apr 27, 2015 | 08:25 AM
bkaul's Avatar
bkaul
If you search on here, I'm sure you can find people doing C2 pump upgrades. You'd need a different bracket and new lines. Not sure the FE was ever available with the C2 pump from the factory, so it may be a custom bracket job... I think for that reason the Saginaw pumps are a popular upgrade on those engines.
Old Apr 27, 2015 | 08:59 AM
greentruck72
found one that said they will bolt on but may need shimed a little. if i find a bed from a 76-79 with the door it should have all of what i need there.
for the pump i all ready know the differences, and have the special line for it.
Old Apr 27, 2015 | 08:36 PM
greentruck72
so what I think I will be doing-
new gear box
new power steer pump
F-350 Brake booster upgrade
tires
Headers-Sanderson ceramic coat/ non may spray with header paint a few times then a high temp clear
body
dress the engine up a little.
paint- most likely 2007 f150 dark grey(gray)
once I get the truck built, I think I may go with a 445 stroker, assuming, I can pay for gas, and the kit itself but that is a maybe
Old Apr 27, 2015 | 09:36 PM
HIO Silver's Avatar
HIO Silver
new gear box
tires
body
That order makes sense. Just remember to avoid doing things twice and to follow a logical sequence. There are some guys who start with the body and end up chipping the paint while R&Ring the engine. Or some who start with the interior (because it is instant gratification) and then get overspray on it.
Clean 'er up and get to it!
Old Apr 28, 2015 | 09:28 AM
greentruck72
oh and I want to do the pertronix kit as well.
the only problem with body is I may have to find a new bed, what years fit, looking to possibly go to fuel door instead of cap
73 fourxfour
Jun 2, 2019 09:01 PM
jt45e
Apr 6, 2019 08:00 AM
USArmyTaterness
Mar 21, 2016 09:55 PM
Hammypj
May 14, 2013 07:21 PM
ThunderFord
37
Mar 26, 2007 01:08 AM
