1983 E250 Getaway Van
Old Apr 20, 2015 | 12:48 PM
NFLDFORD's Avatar
NFLDFORD
This is a class B motor home. The Getaway Van was built in BC Canada .
Old Apr 20, 2015 | 12:56 PM
NFLDFORD's Avatar
NFLDFORD
Engine swap
I am replacing the original 302 with a 351 4 brl. I Got a complete donor van with a rebuilt 351. Any info on the things that must be changed , would be a great help thanks. I am swapping out the engine and transmission together., without separating them.
Old Apr 20, 2015 | 01:27 PM
NFLDFORD's Avatar
NFLDFORD
Old Apr 21, 2015 | 12:28 AM
fordman75's Avatar
fordman75
Nice van! I would like to find an extended E350 version of your van.
If your 351 is a 351W and not a 351M it should be pretty much a bolt in deal.
The 351W shares the same motor mounts as the 302. So no messing with the frame perches/towers.
Are both transmissions non OD automatics? If there are then they are Both C6 automatics.
I believe the exhaust Y-pipe will be different. So if you can use the one out of your donor van then you'll be set with that.
Use whichever radiator is bigger too.
Just don't get rid of your donor van until the swap is finished. That way if there are any small parts that you need, you'll have them right in the other van. I made that mistake back in my youth. I stripped everything I thought I would need and scrapped the rest. Only to find out I missed some things I needed.
Old Apr 21, 2015 | 02:04 AM
68Mercury250Ranger's Avatar
68Mercury250Ranger
I agree with the previous post including the part about looking or an extended version......................... damn hard to find in the Great white north
that is a sharp looking van yet with cool 80s colours
Old Apr 21, 2015 | 10:13 AM
NFLDFORD's Avatar
NFLDFORD
Thanks guys. I have not done a swap in over 20 years and I'm not sure what I may be forgetting.
Old Apr 21, 2015 | 10:16 AM
NFLDFORD's Avatar
NFLDFORD
[QUOTE=68Mercury250Ranger;15288926]I agree with the previous post including the part about looking or an extended version....yea I would love the extra space in the extended van. The longest E350 with the 460 would be nice.
Old Apr 21, 2015 | 10:24 AM
NFLDFORD's Avatar
NFLDFORD
[QUOTE=fordman75;15288864]Nice van! I would like to find an extended E350 version of your van
NO , Both have OD
Yea I am also using it to fill full of old parts. I also get power Windows and locks, inside door handle for the back doors.
Thanks for your input.
Old Apr 21, 2015 | 12:52 PM
fordman75's Avatar
fordman75
[QUOTE=NFLDFORD;15289969]
NO , Both have OD
What year is your donor van? If it's a factory 351W 4V then I would be guessing it's in the 84-87 range. And does it have an OD button on the dash? If it does not have an OD button then both transmissions should be AOD's and not an E4OD, which would complicate the swap.
Old Apr 21, 2015 | 02:08 PM
NFLDFORD's Avatar
NFLDFORD
85 E150 clubwagon but I was mistaken it is not an OD transmissions
83 E250 getaway. OD on the shifter ( OD D. 2. 1)
Old Apr 21, 2015 | 02:59 PM
fordman75's Avatar
fordman75
Does your shifter have a button on it for OD? I don't think they had an electric OD transmission in 83. If your shift indicator goes: P,R, D ( with circle around it ) , 2, 1 with no button. Then it's the AOD.
If your 351W donor has the C6 and the E250 has the AOD you are going to run into some differences when swapping them. It's been a long time since I owned anything with the AOD. But you might get into wiring differences ( for the nuetral safety switch ) , shift linkages, driveshaft length and possibly even need to swap out the steering column ( unlikely but possible ) . Like I said it's been close to 20 years since I owned anything with an AOD. So I'm just going off my crappy memory.
Old Apr 22, 2015 | 12:28 PM
NFLDFORD's Avatar
NFLDFORD
Yea I can relate. its been over 20 years since the last engine swap I did
Old Apr 22, 2015 | 12:41 PM
68Mercury250Ranger
your 83 E250 won't/shouldn't have an overdrive trans.
it is probably a C6 also, they look completely different. you would be able to see the difference with a quick roll under and a flashlight.
Old Apr 22, 2015 | 01:24 PM
fordman75's Avatar
fordman75
If he's a lucky dog he might also have one that someone added a Gear Vendors unit to.
You can ID the transmission by the shape of the pan on it. Due to your vans ages I would say they are either AOD or C6. But someone could have also swapped them out for something else in the past.
Here's a couple pics to help.
Old Apr 22, 2015 | 01:35 PM
NFLDFORD's Avatar
NFLDFORD
ShiShifter indicindicator in the 1983 E250 GetGetaway Van
